Page 2 of 6 1 2 3 4 5 6
Re: 440 Six Pack won't run for crap [Re: superwrench] #1443492
05/28/13 10:38 PM
05/28/13 10:38 PM
Wahoo Nebr
vette1986 Offline OP
Wahoo Nebr
Well I got out a can of starter fluid and started spraying once I got it warmed up. I can go all the way down the drivers side head and around the carbs with no increase in rpm. Then when I go to the back of the passengers side right below the coil the rpm will go up a couple hundred rpm each time I spray around there. I also hear a sound which I thought was an exhaust leak in that general area but I am thinking it must be an intake gasket leak. Would that normally make a sound like an exhaust leak though? Definetly something not right back there so looks like the engine builder did not get the intake on correctly and now we will have to pull it. Anyone have any input before I crack it open??
1969.5 A12 Bee EV2
1971 Charger RT
1973 Duster tubbed 500 low deck 10.90 monster
3 440 polara vert projects
Re: 440 Six Pack won't run for crap [Re: vette1986] #1443493
05/29/13 12:24 AM
05/29/13 12:24 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Pull the intake , if it doesn't have paper gaskets between the intake and the valley pan one on each bank , put the intake back and see what it does .
Re: 440 Six Pack won't run for crap [Re: JohnRR] #1443494
05/29/13 01:13 AM
05/29/13 01:13 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Yep...heading in the right direction. Get the intake sealed up and lets go from there. Don't forget to check those outboard carbs for adjustment too...
Re: 440 Six Pack won't run for crap [Re: superwrench] #1443495
05/29/13 02:10 AM
05/29/13 02:10 AM
500 cubes/stealth heads & it ain't been right since day 1 with the massive intake leak. With a killer eng like this you're gonna have a smile on your face once you get it sealed up/tuned
Re: 440 Six Pack won't run for crap [Re: RapidRobert] #1443496
05/29/13 03:08 AM
05/29/13 03:08 AM
You think OP, once you get the intake sealed up try setting the outboard linkage up on the center carb. by screwing each end rod out longer than needed to insert it into the linkage on the center carb. Then adjust each one of those so they just fit with the outboard throttle shafts closed all the way with the idle speed screw on the center carb. backed out all the way, adjust from there One other thing is to check the idle mixture screws on the outboard carbs, remove the lead plugs if neccesary and adjust them in all the way carefully,do not FORCE THEM in ,then adjust them out 1/4 to 1/2 turn each on both sides. set the center carb. mixture screws from 1 1/2 to 2 full turns out from bottoming out also, then set the idle speed off of the center carb. My last six pak idled at 850 RPM in gear with a lot bigger cam than yours, it took some tuning to do that also You can make it work good also
Re: 440 Six Pack won't run for crap [Re: JohnRR] #1443497
05/29/13 08:36 AM
05/29/13 08:36 AM
Wahoo Nebr
Wahoo Nebr
Since I am going to have it off the engine anyone have any input on what jets, squirters, secondary springs, and pv I should put in since I will have it off? I know I should probably seal up the intake first but since I will have it all off on the bench it would be easy to do since it sounds like it will need something a little bigger. Thanks for all the help guys.
1969.5 A12 Bee EV2
1971 Charger RT
Re: 440 Six Pack won't run for crap [Re: vette1986] #1443498
05/29/13 08:42 AM
05/29/13 08:42 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
If it is a stock 6-pack set up I'd jump to 70 jets, 33-35 squirters, maybe drop down on the PV also, not sure what type of vaccum that cam should pull. I have yet to change out my acc pumps but I've been to told go up to 50cc. As for springs, try it on the street 1st. I eneded up with the purples and it flat out hauls tail. Once you get it tuned hang on.
Re: 440 Six Pack won't run for crap [Re: vette1986] #1443499
05/29/13 09:13 AM
05/29/13 09:13 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The other thing you need to do is open up the idle feed restrictions in the top of the end metering plates from the factory .037 to .040,will make a big difference in your ability to get good idle.
Re: 440 Six Pack won't run for crap [Re: 62maxwgn] #1443500
05/29/13 10:26 AM
05/29/13 10:26 AM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
good idea to pull the intake. when you have it off remove the carbs. look at the throttle plates from the bottom side of the carbs and make sure that they closed all the way and are centered in the bores. get a promax base plate and jet plate. i agree with the 70 jets and 33-35 sqt.can't see how it runs with only 6* inital, would seem like the throttle plates are open,are you using a dial back timing light, if so make sure it is set at zero. when setting the idle disconnect the outboards. there is a really good post here about tuning and adj the six pack, it is a bit long but very good check the tech archives. i have it saved to my favorites maybe i could forward it to you.
Re: 440 Six Pack won't run for crap [Re: lokalik] #1443501
05/29/13 10:39 AM
05/29/13 10:39 AM
Wahoo Nebr
Wahoo Nebr
yeah shoot me that link. When I look down the bores of the outboards they look closed but they are tipped a little bit should they be completely level like the secondaries in my old 4 barrel? This is my first round with a 6 pack and am having a learning curve on it.
1969.5 A12 Bee EV2
1971 Charger RT
Re: 440 Six Pack won't run for crap [Re: vette1986] #1443502
05/29/13 10:40 AM
05/29/13 10:40 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
brand new remanufactured carbs
Are they an original set that has been rebuilt? Or are they brand new? I've seen some sets of 1969 originals that had the "kill bleed" holes drilled oversize in the outboard carbs which prevents them from opening with vacuum.
Re: 440 Six Pack won't run for crap [Re: Dave Watt] #1443503
05/29/13 10:47 AM
05/29/13 10:47 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Dave,they are supposed to be .043,I've had some as much as .090 !
Re: 440 Six Pack won't run for crap [Re: 62maxwgn] #1443504
05/29/13 12:34 PM
05/29/13 12:34 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
.090" is what size mine were. They never would open until I put restrictors in.
Re: 440 Six Pack won't run for crap [Re: Dave Watt] #1443505
05/29/13 07:47 PM
05/29/13 07:47 PM
Wahoo Nebr
Wahoo Nebr
going to pull the intake tonight, what should a factory aluminum intake be torqued to? I will use a small amount of black rtv on both sides of the gasket should I use sealant anywhere else to be safe? Thanks
1969.5 A12 Bee EV2
1971 Charger RT
Re: 440 Six Pack won't run for crap [Re: vette1986] #1443506
05/29/13 07:55 PM
05/29/13 07:55 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I dont really like RTV on the valley pans, usually use copper spray on them though, just some RTV in the corners where it meets the block/heads.
Since you've got a leak though you may want to consider something. Are you using paper gaskets in addition to the valley pan?
Re: 440 Six Pack won't run for crap [Re: vette1986] #1443507
05/29/13 08:40 PM
05/29/13 08:40 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
Wow.
My experiance suggests that you'll be pretty close with stock jetting. Hard to imagine that you would need 70s (comes with 62 or 63) in the center unless you have the mixture screws on the outboard cabs nearly closed.
Re: 440 Six Pack won't run for crap [Re: BSB67] #1443508
05/29/13 09:03 PM
05/29/13 09:03 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Wow.
Never had to go above 65's on this and it is not stock,runs like a clock !
Re: 440 Six Pack won't run for crap [Re: 62maxwgn] #1443509
05/29/13 09:51 PM
05/29/13 09:51 PM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
each motor is different. don't think just because everyone says to run 16 to 18 intial and 36 to 38 total is correct, this is abunch of b/s. my 383 6pk loves 22 inital and runs great with48 total. i run 70's with a 33 squrt, point is find out what works for your gig. standard usual b/s can be a baseline and thats all. i'm not saying that there aren't issues at play here however, there is a correct starting point and then work from there. i'll see if i can get you this tech archive but ANYONE on this site that has a 6pk has read this article, it helped me a bunch. can't figure out how to link the tuning info to you. get a hold of DAYCLONA, member here, he is the one who posted it, great tuning info, follow it step by step. hope this helps.
Re: 440 Six Pack won't run for crap [Re: lokalik] #1443510
05/29/13 10:07 PM
05/29/13 10:07 PM
superwrench Offline
superwrench  Offline
WOW!! 48* total??? Without vacuum advance?? I'd be a little leary that there won't be any rod bearings in that motor REAL quick....
Re: 440 Six Pack won't run for crap [Re: superwrench] #1443511
05/29/13 10:18 PM
05/29/13 10:18 PM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
who said i was not running vac adv. real quick you mean as in 8 years later or real quick as to the e/t of your car getting thru the 1/8.
