Re: Need Traction [Re: Bad340fish] #1442749
05/29/13 08:49 AM
05/29/13 08:49 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
BAD340...no im not,I will pull the shocks off and try to bounce it.Maybe tubular upper arms & strut rods should be the next change
I have the rms uppers and strut rods. It's easier to move the whole assembly through its travel than it is to move just the stock uca with poly bushings.
He said he wanted a "low cost option".....used slicks/soft sidewall tires is as low as it's gonna get....
If you can't handle the truth, you're living a lie.......
Re: Need Traction [Re: 340_Dart] #1442750
05/29/13 11:21 AM
05/29/13 11:21 AM
arizona
HP318 Offline OP
HP318  Offline OP
arizona
340...its got 6 cyl t bars
