Re: TCI aluminum deep pan leaking - Part 2
[Re: gpuller]
#1442532
05/27/13 02:20 AM
05/27/13 02:20 AM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
That will be the next gasket I'll use if this one leaks again after I find a way to keep the bolts tight. I got a fel-pro gasket, a new one again, and put the high tack gasket sealer on all four surfaces. Let it dry to a tacky touch. Installed pan. Didn't put any fluid in for over 24 hours. Ran the car a few miles, got home, no leakes, and checked the bolts. They were ever so slightly loose. Tightened them again. Drove a few miles today, got home and pan was leaking. Bolts were loose again. Tightened them again! Drove a few miles again, got home no leaks. Checked bolts, they were loose again!! About maybe an 1/8 of a turn to tighten them except two that took about a 1/4 turn to tighten them. Don't know why the bolts keep coming loose so I want to try the Blue Threadlocker. Hopefully that will keep the bolts tight and the pan from leaking.
[Re: Junky]
#1442533
05/27/13 02:23 AM
05/27/13 02:23 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
P/N 2464324AC
that should be the only gasket you use...and they are reusable too...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Junky]
#1442534
05/27/13 08:21 AM
05/27/13 08:21 AM
Posts: 11,657 Fitchburg,Massachusetts
MPerry
Mopahts memba'
Mopahts memba'
Are you positive its the pan leaking? I only ask because I thought my cast pan wasn't sealing only to find out it was my dipstick tube o ring. I needed to install a new o ring with some rtv smeared on it to stop the leak. Shift seals are also another potential leak source that makes it look like its a pan leak.
[Re: 70AARcuda]
#1442536
05/27/13 11:58 AM
05/27/13 11:58 AM
Posts: 1,630 North Central Florida
eightlitermopar
I also had a TCI pan that I finally got to seal. I soon found out I had a bad casting and it was leaking THROUGH the pan. 1 little pinhole. I returned that pan, got another, used the gasket mentioned and used lock-washers on the bolts. That seemed to do it. eightlitermopar
Mopar or no car
[Re: 70AARcuda]
#1442538
05/27/13 12:50 PM
05/27/13 12:50 PM
Junky
Wherever I am.
P/N 2464324AC
If the Blue Threadlocker doesn't work keeping the pan bolts tight, I'll be trying that gasket for sure.
[Re: dOrk !]
#1442540
05/27/13 02:58 PM
05/27/13 02:58 PM
Junky
Wherever I am.
How loose are the bolts in the treads of the trans case ?.... OTHER THAN getting some of those nylon inserted bolts(they have been used on some of the B/RB and Hemi engine oil pans) .... I would try a simple lite lock washer....
Sorry, Doc, I don't understand what you are trying to tell me.
The bolts for the pan have lock washers.
The trans is fine.
No plastic anywhere.
[Re: Junky]
#1442542
05/27/13 05:04 PM
05/27/13 05:04 PM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
The trans is fine.
JUNKster ... show us a pic of those bolts. You have never seen those ny-lock bolts ?
[Re: dOrk !]
#1442546
05/27/13 06:38 PM
05/27/13 06:38 PM
MPerry
Mopahts memba'
Mopahts memba'
mBerri ....I would worry about pulling the threads OUT OF the trans case ....
Pulling with blue locktite???
[Re: dOrk !]
#1442547
05/27/13 11:28 PM
05/27/13 11:28 PM
Junky
Wherever I am.
The trans is fine.
Doc, never seen those before.
Would those work better than the bolts that came with the pan and Permatex Blue Threadlock, Locktite, Locktight? That one.
