Re: Horsepower loss with Dry Sump?? [Re: Hemi_Joel] #1441315
05/25/13 03:37 PM
05/25/13 03:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
...Also 50 psi is really all you need at full boogy. There is a regulator on the rear of the pump to adjust pressure. But, slowing the pump down is the first step if you have plenty of pressure at hot idle.
Leon
Joe mondello (rip) always said that you need 10 psi per 1000 RPM, to overcome centrifugal force. Has that changed? I sure would want more than 50 psi at 7800 rpm.
Also I forgot to say that the more vac I ran, the
oil pressure showed lower by that amount(or close)
Re: Horsepower loss with Dry Sump?? [Re: Al_Alguire] #1441316
05/27/13 09:30 PM
05/27/13 09:30 PM
Greensburg, Pa
Mpetros Offline OP
Mpetros  Offline OP
Greensburg, Pa
Its a Stock Car Products Dry Sump Pump..
Re: Horsepower loss with Dry Sump?? [Re: Performance Only] #1441317
05/27/13 09:41 PM
05/27/13 09:41 PM
Greensburg, Pa
Mpetros Offline OP
Mpetros  Offline OP
Greensburg, Pa
I dont have those numbers with Me here at Home..
But The Place that I Dyno The Operator probably the best at correction factors that I know of.. I know with him I have honest Horsepower numbers He is a no BS kind of Guy..
