Re: Lickity Splits fire system saves it
[Re: dvw]
#1441147
05/24/13 10:42 AM
05/24/13 10:42 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
And of coarse there's a fire nozzle in the interior as well.
I'm just glad nobody got hurt!!
Thoses seats,,,,,,,,,that would have been the stain I left agter the ka,boom ![](/ubbthreads/images/graemlins/whistling.gif)
Re: Lickity Splits fire system saves it, Pictures fixed
[Re: 340RICK]
#1441153
05/27/13 12:41 PM
05/27/13 12:41 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Doug when that happen to us we put longer bolts in and was racing in an hour. I know you want to make sure things are all right but remember it blew out not suck in so everything went out. You will probably not find anything in the heads .
JAKES AUTOMOTIVE
[Re: dvw]
#1441154
05/27/13 12:54 PM
05/27/13 12:54 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
I decided to go to the Track with my son and leave the problems sit a few days. I'll pull the heads today to check for any pieces that might have made it inside of the ports. Now that I think about it spinning the motor with ignition off probably contributed. Bob, do you have any pictures of the pieces you weld in? I like Rat Patrols blow off valve. Anybody know where to get that style valve/plate? It has a MSD 7al2 box w/crank trigger at 32 degrees. I'll check the carbs as well. In fact as long as the steering linkage off to remove the headers Ill pop the pan for a bearing check as well. Doug
Doug.I don't have any pictures,maybe some of the guys that have my modified manifolds can post a picture.I would put 2 Wilson blowoff valves at the front and back corners and keep them away from the carbs.I have done 8 manifolds and Jim(572 Charger) you dont have this problem with TRs just tub style manifolds where fuel can puddle.Jon and Kevin have two of these manifolds that I have modified. ![](/ubbthreads/images/graemlins/bow.gif)
[Re: B G Racing]
#1441155
05/27/13 11:04 PM
05/27/13 11:04 PM
Posts: 9,894 MI, usa
dvw
MI, usa
Pulled the heads,found no shrapnel. My theory was if an intake was open the pressure could have sent a piece down the hole. As long as the steering linkage and diaper were off I pulled the pan and checked the rod bearings. I'll put the heads back on tomorrow. Has anyone back fired one of these after the blow off valve install? I can see why it popped the top. Only had 3 threads of engagement of the lid bolts. Total carnage. Melted 2 temp sensor wires,1 vacuum line, 1 accelerator pump(there plastic on Eddelbrocks,throttle cable, fill the fire bottle, distributor rotor (Intake knocked the distributor cap off), very lucky.
[Re: dvw]
#1441156
05/27/13 11:43 PM
05/27/13 11:43 PM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
I have backfired mine after I had the Bob George made blow off valves on and they worked. I have also seen guys with the Wilson valves backfire and they also work well. And yes the top bolts are short and I replaced all of mine with longer ones. Indy always told me there was no issue with these intakes but said the short bolts are a safeguard in case it did happen ![](/ubbthreads/images/graemlins/image_294343.gif) The epoxy inserts from Indy also help with the puddling of fuel and I did install them too. If you want I can get a pic of what they look like intsalled. Just seems like with the big plenum volume backfires will happen and even more so when cold starting. I knew there was always a chance on start up but my 2nd blowup was while driving through the pits so that was different. Russ
