Re: Pics of the diaper I made. [Re: rt66jim] #1440900
05/24/13 12:18 AM
05/24/13 12:18 AM
Toronto
mshred Offline
mshred  Offline
Toronto
Thanks for all the positive replies. Maybe I need to go into business? I can see it now Diapers by Jim.
LOL...Awesome work! But the post above yours that said "awesome diaper" actually had me laughing...I must be immature, but it sounds funny LOL
Re: Pics of the diaper I made. [Re: Jeepmon] #1440901
05/24/13 01:51 PM
05/24/13 01:51 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Just out of curiosity.. any idea how that material will hold up to the heat? specially when it gets close to headers...
This would probaly do the job.
http://www.fiberglasssupply.com/Product_...CFW2oPAodQUMAmQ
Re: Pics of the diaper I made. [Re: rt66jim] #1440902
05/25/13 10:57 AM
05/25/13 10:57 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
awesome work Jim...
I have a question:..do these need to be SFI compliant??...
Re: Pics of the diaper I made. [Re: smokinwoody] #1440903
05/25/13 12:31 PM
05/25/13 12:31 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
I have heard they need to be for the pro classes but not the sportsman.
http://www.enginediapers.com/
Re: Pics of the diaper I made. [Re: rt66jim] #1440904
05/25/13 12:53 PM
05/25/13 12:53 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
thanks Jim..
What does an engine diaper do?
-When installed properly, an engine diaper (or lower engine containment device) will keep oil and debris from getting onto the track.
How hard is it to install?
-It’s very easy to install! Because we incorporated quick release buckles and 4 simple straps, they install simply and snugly around your engine.
Why do I need an engine diaper?
-First and foremost, safety. A DRE engine diaper is much cheaper than replacing a car. Having a DRE engine diaper also means less track downtime. And there are IHRA and NHRA requirements.
What diaper are Sportsman required to run?
-You are only required to run an NHRA accepted diaper, as per chart on NHRA Website.
What is SFI 7.2?
-NHRA has changed the rules. You do not need to run a SFI 7.2 diaper to any sportsman car.
Re: Pics of the diaper I made. [Re: smokinwoody] #1440905
05/25/13 08:26 PM
05/25/13 08:26 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
for sportsman there are no specs but it must be on the list. translation NHRA got paid to "inspect" an item that has no specification for safety or construction and add it to their approved list.
home of the
Sox and Martin Hemi Duster
Re: Pics of the diaper I made. [Re: HEMIFRED] #1440906
05/25/13 08:52 PM
05/25/13 08:52 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
If you make your own diaper it can only be used on cars that don't require them?
Re: Pics of the diaper I made. [Re: MPerry] #1440907
05/26/13 04:04 PM
05/26/13 04:04 PM
Guitar Jones Offline
That looks like really nice work. If I had a sewing machine I might attempt it but I don't. I do have welders though so I think I'll make a belly pan instead.
Re: Pics of the diaper I made. [Re: Guitar Jones] #1440908
05/26/13 04:31 PM
05/26/13 04:31 PM
Q
Quicktree Offline
Quicktree  Offline
Q
the belly pan is so simple, I like the one on my arrow in fact I am going to extend it a little to cover the tranny.
Re: Pics of the diaper I made. [Re: Quicktree] #1440909
05/26/13 06:30 PM
05/26/13 06:30 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Pics.
Re: Pics of the diaper I made. [Re: Quicktree] #1440910
05/26/13 06:31 PM
05/26/13 06:31 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Is it SFI approved?
