Re: Help with Drive Line Vibration [Re: DAYCLONA] #1439454
10/28/13 12:18 PM
10/28/13 12:18 PM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
Maybe double check the condition of the trans mount?
Re: Help with Drive Line Vibration [Re: DAYCLONA] #1439455
10/28/13 12:41 PM
10/28/13 12:41 PM
Wisconsin
Mopar_Mudder Offline OP
Wisconsin
What's the "history" of the shaft?, isn't that part of the Hurst kit...or?
The shaft is brand new from Inland Empire Driveline.
The tranny mount is new polyuretheane, thinking about repacing it for a rubber one.
1971 Hemi Cuda 2005 SRT-10 Regular Cab Flame Red. 12.771 @ 109.67<---TIME SLIP--Video
Re: Help with Drive Line Vibration [Re: Mopar_Mudder] #1439456
10/28/13 05:12 PM
10/28/13 05:12 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've always run the poly mount on TKO swaps, no issues...I'd ask Inland Empire what there balance speed is when they balance a shaft,...suprisingly most shops only balance up to 3500 RPM,....you want a shop that can balance up to 10,000 RPM shaft speed, for a TKO application
Mike
Re: Help with Drive Line Vibration [Re: DAYCLONA] #1439457
10/28/13 08:00 PM
10/28/13 08:00 PM
Wisconsin
Wisconsin
I actually want to try the rubber mount to see if it will get rid of another RPM related vibration. Guess I would really call it a vibration maybe more of a harmonic thing. Starts about 3000 rpms in all gears or neutral even. But from out side the car things all seem pretty smooth.
I want to get the drive shaft checked. But I have been putting it off because I have to pull that exhaust apart to get the shaft out. And getting the exhaust apart is hell and then some
Re: Help with Drive Line Vibration [Re: DAYCLONA] #1439458
10/29/13 04:05 PM
10/29/13 04:05 PM
Wisconsin
Wisconsin
Mike
Inland maxes out at 3500 they said, not that they balanced it that high.
Called a couple shops around here and most balance at 500 maybe 2500. They never heard of balancing that high
Re: Help with Drive Line Vibration [Re: Mopar_Mudder] #1439459
10/29/13 05:00 PM
10/29/13 05:00 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Mike
Keisler balances all their shafts at 10,000 RPM, they are one of only a handful of shops with the capability, most shops are only using conventional lathes to balance their shafts, very few actually invest in dedicated balancing equipment
Mike
Re: Help with Drive Line Vibration [Re: DAYCLONA] #1439460
10/29/13 05:01 PM
10/29/13 05:01 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Mike
Why?
That would be 8200 rpm engine speed in 6th and there is no way your drive shaft will ever see 10000 rpm in any other gear (or in 6th for that matter).
Don't be the exception.
Re: Help with Drive Line Vibration [Re: DAYCLONA] #1439461
10/29/13 05:03 PM
10/29/13 05:03 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yes and we all know that the Gospel according to Keisler is the truth, the whole truth and nothing but the truth.
I wouldn't believe Kiesler if they told me water was wet.
Re: Help with Drive Line Vibration [Re: Supercuda] #1439462
10/29/13 05:06 PM
10/29/13 05:06 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Mike
Why?
What about a .50 OD application?...
Re: Help with Drive Line Vibration [Re: DAYCLONA] #1439463
10/29/13 05:26 PM
10/29/13 05:26 PM
Wisconsin
Wisconsin
Mike
Why?
Actually drive shaft speed is dictated by gear ratio and tire size.
Lets see 10,000 rpm with a 4:10 gear and my F60-15's would be 188 MPH and 6400 rpm on the engine. (this is baced on a .64 OD )
Yes the pucker factor would be HIGH
Re: Help with Drive Line Vibration [Re: DAYCLONA] #1439464
10/29/13 05:47 PM
10/29/13 05:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Mike
Why?
Did the TKO600 come with a .5 OD ratio?
I see a .82 and a .64, no .50
What road speed would you be doing at 5000 engine rpm in OD? or 6400 engine rpm?
Re: Help with Drive Line Vibration [Re: Supercuda] #1439465
10/29/13 05:55 PM
10/29/13 05:55 PM
Wisconsin
Wisconsin
My numbers in above post are based on a .64 OD
I know what you are saying that you will never see that speed. But it would stand to reason that faster you spin the shaft the more acuraccy you would see in balancing it.
Re: Help with Drive Line Vibration [Re: Mopar_Mudder] #1439466
11/04/13 11:46 AM
11/04/13 11:46 AM
Wisconsin
Wisconsin
Another update.
I installed a stock rubber tranny mount yesterday. Looks wimpy compared to the poly one but I put it in anyways. It did seem to change the vibration some. It is not as high of pitch/frequency now, a little bit lower. I don't know that it help it or is just masking it so you don't feel it as much. Also in the past I have noticed that the vibration get worse as the further you drive and get stuff warmed up more. It was only 45 degs last night so I am sure things didn't get warmed up as much, but I was able to go 80 with out feeling like I was pushing it too hard.
I think I am going to work on exhaust next. I notice that a drone in the exhaust actually comes in about the same time as this vibration, wonder if the two could be related some how? Have to try an figure a way to get a resinator in the exaust, not much room to do it....
Also I checked the drive shaft for run out while I was at.
Rear = .014
Middle = .0075
Front = .009
Re: Help with Drive Line Vibration [Re: Mopar_Mudder] #1439467
11/04/13 05:39 PM
11/04/13 05:39 PM
Rear = .014
Middle = .0075
Front = .009
the numbers APPEAR to be low but you might call a driveline specialty shop & run it past them what's going on & see what they say
Re: Help with Drive Line Vibration [Re: RapidRobert] #1439468
11/04/13 06:12 PM
11/04/13 06:12 PM
Wisconsin
Wisconsin
Rear = .014
Middle = .0075
Front = .009
Yea I am going to get rebalnced again. But they are talking 4-6" of snow tomarrow night. So I think I am done until spring now.....
Re: Help with Drive Line Vibration [Re: Mopar_Mudder] #1439469
11/04/13 08:56 PM
11/04/13 08:56 PM
they're all going to say bring it in & lets balance it. Hopefully you can find one that's honest about it otherwise you'll pay for another balance job & that wont fix the problem cuz it's balanced OK right now but people have reported on occaision in severe cases that it took several different shops till one of em got it right. Holler how it goes.
