Re: Help with Drive Line Vibration
[Re: DAYCLONA]
#1439455
10/28/13 01:41 PM
10/28/13 01:41 PM
Posts: 374 Wisconsin
Mopar_Mudder
Wisconsin
What's the "history" of the shaft?, isn't that part of the Hurst kit...or?
The shaft is brand new from Inland Empire Driveline.
The tranny mount is new polyuretheane, thinking about repacing it for a rubber one.
[Re: Mopar_Mudder]
#1439456
10/28/13 06:12 PM
10/28/13 06:12 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I've always run the poly mount on TKO swaps, no issues...I'd ask Inland Empire what there balance speed is when they balance a shaft,...suprisingly most shops only balance up to 3500 RPM,....you want a shop that can balance up to 10,000 RPM shaft speed, for a TKO application
Mike
[Re: DAYCLONA]
#1439458
10/29/13 05:05 PM
10/29/13 05:05 PM
Mopar_Mudder
Wisconsin
Mike
Inland maxes out at 3500 they said, not that they balanced it that high.
Called a couple shops around here and most balance at 500 maybe 2500. They never heard of balancing that high
[Re: Mopar_Mudder]
#1439459
10/29/13 06:00 PM
10/29/13 06:00 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Mike
Keisler balances all their shafts at 10,000 RPM, they are one of only a handful of shops with the capability, most shops are only using conventional lathes to balance their shafts, very few actually invest in dedicated balancing equipment
Mike
[Re: Supercuda]
#1439462
10/29/13 06:06 PM
10/29/13 06:06 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Mike
Why?
That would be 8200 rpm engine speed in 6th and there is no way your drive shaft will ever see 10000 rpm in any other gear (or in 6th for that matter).
What about a .50 OD application?...
[Re: Supercuda]
#1439465
10/29/13 06:55 PM
10/29/13 06:55 PM
Mopar_Mudder
Wisconsin
What road speed would you be doing at 5000 engine rpm in OD? or 6400 engine rpm?
My numbers in above post are based on a .64 OD
I know what you are saying that you will never see that speed. But it would stand to reason that faster you spin the shaft the more acuraccy you would see in balancing it.
[Re: RapidRobert]
#1439468
11/04/13 07:12 PM
11/04/13 07:12 PM
Mopar_Mudder
Wisconsin
Also I checked the drive shaft for run out while I was at.
Rear = .014 Middle = .0075 Front = .009
the numbers APPEAR to be low but you might call a driveline specialty shop & run it past them what's going on & see what they say
Yea I am going to get rebalnced again. But they are talking 4-6" of snow tomarrow night. So I think I am done until spring now.....
[Re: Mopar_Mudder]
#1439469
11/04/13 09:56 PM
11/04/13 09:56 PM
RapidRobert
they're all going to say bring it in & lets balance it. Hopefully you can find one that's honest about it otherwise you'll pay for another balance job & that wont fix the problem cuz it's balanced OK right now but people have reported on occaision in severe cases that it took several different shops till one of em got it right. Holler how it goes.
