Re: Rid of Mopar electronic mess! UPDATE!
[Re: superbeedave]
#1437725
06/09/13 02:37 PM
06/09/13 02:37 PM
Posts: 15,487 Florida
scratchnfotraction
you have the ignitorII correct? does it have a fixed airgap? I have bumped mine when R&R the dist and had issues till i reset the gap at .030 my pertronix in my mallory duel point dist has a fixed airgap. just thinking out loud. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: superbeedave]
#1437726
06/09/13 07:04 PM
06/09/13 07:04 PM
Posts: 75,112 A Banana Republic near you.
JohnRR
Okay, For the past month I have been experimenting with the 90's mopar electronic ignition and a petronix and coil in my stock distributor and a newer mallory built mopar distributor and I have to be frank, the petronix revs up so much quicker than the other two elect. setups! I do have the ballast bypassed on the petronix and I have the orange box with a .8 resistor for the other elct. setups. But with the petronix ignition the timing marks seems to jump around 2-3 degrees with my dial back timing light and it did annoy me. Can anyone explain to me why this is? Thanks, Dave!
There is your first problem , the orange box , it's as big a POS as a cone type suregrip ...
your timing is bouncing around probably due to slop in the distributor to oil pump drive clearances ...
[Re: superbeedave]
#1437727
06/09/13 07:06 PM
06/09/13 07:06 PM
JohnRR
#1, I had it for a little over 3 years and just recent I decided to try it out. What was weird was when i installed it a few weeks ago I used a Mallory high perf. coil for points and the timing marks didn't jump around. Then when I put on the petronix coil that is when the marks started bouncing around.
Then the problem here is the coil , pertronics coils now are off shore junk. Paint the mallory coil black and run it .
[Re: scratchnfotraction]
#1437728
06/09/13 08:42 PM
06/09/13 08:42 PM
Posts: 508 Cincinnati, Ohio
superbeedave
Cincinnati, Ohio
It's the ignitor 1
[Re: Paul_Fancsali]
#1437732
06/09/13 10:10 PM
06/09/13 10:10 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
One has to wonder how the heck millions of Mopars survived with the electronic ignition some of you have issues with.
I've run the Orange ECU in numerous cars over the years with no problems. Closest I ever came was when an Accel yellow coil failed when it got hot.
[Re: 383man]
#1437733
06/10/13 12:37 AM
06/10/13 12:37 AM
JohnRR
Funny as many say the orange box is no good but mine has worked flawless since 2000 when I first put it on my boys Dart. I now run it on my 63 with an Acell coil. When we took it off his car and put MSD on it it did not sound any different and started the same. It also did not go any faster with the MSD. Sorry to hear so many have had trouble with them. Mine never misses a beat and the timing is right on all the time. Good enough for 6500 RPM and 10 second et's. Ron
Put a timimg light on it and tell us what the timing is at 3500 , 4000 , 4500 , 5000 , 5500 ...
I'll say this much , back around 1984 I put an Accel dual point race distributor on my dads duster with a 340 , switched it to mopar electronic after my brother kept leaving the ignition on and burning out points while he was PARKING in the car. The car ran so much better and sounded stronger with the Dual point than it did wit hthe orange box.
Comparing an orange box from 13 plus years ago to something current is not an apples to apples comparison if the old ones do not pull timing out like the current ones do.
[Re: JohnRR]
#1437734
06/10/13 12:57 AM
06/10/13 12:57 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
[Re: 383man]
#1437735
06/10/13 01:10 AM
06/10/13 01:10 AM
JohnRR
Maybe I am just a lucky one John ? Ron
Maybe you are ?
All I know is the orange box that came with my 2005 crate hemi pulls out timing above 4000 rpm.
[Re: JohnRR]
#1437736
06/10/13 08:36 AM
06/10/13 08:36 AM
Posts: 965 S.W. Pennsylvania
markrr
S.W. Pennsylvania
Maybe you are ?
Could you please explain what pulling out timing means?
[Re: RapidRobert]
#1437738
06/10/13 10:02 AM
06/10/13 10:02 AM
markrr
S.W. Pennsylvania
instead of just opening the coil primary circuit when triggered by the dist coil pickup it improperly electronically delays that precise moment at higher RPM's which retards the timing (kinda like a dialback timing light does). An ECU is only supposed to open/close that circuit when triggered by the dist but evidently something is electronically wonky in some of the newer orange boxes causing it to do something (delaying the opening of that wire) that it should not be doing
Got it! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: RapidRobert]
#1437739
06/10/13 10:08 AM
06/10/13 10:08 AM
JohnRR
Robert I don't think something is wonky in the electronics , I think it's by design. Before the current Mallory internals of the supplied with the electronic conversions the distributors supplied had 30 degrees or more of mechanical advance. The easiest way to make a one size fits all conversion was to have the electronics pull out timing instead of instructing the end user to do the trial and error process of welding the slots to limit mechanical advance.
[Re: JohnRR]
#1437740
06/10/13 10:14 AM
06/10/13 10:14 AM
RapidRobert
Double R that does make sense cuz you certainly wouldn't expect it to be doing that (or be electronically capable of doing that) if it wasn't designed into it
[Re: jlatessa]
#1437742
06/10/13 11:32 AM
06/10/13 11:32 AM
JohnRR
Is there any way short of checking the timing at 5500 to identify bad orange boxes?
We purchased ours quite a while ago and haven't installed yet, I would like to avoid replacing after the fact is discovered.
I still have the conversion pack box, but can't see any date on it.
The part# is 23690428, is that any clue?
Thanks, Joe
It's not necessarily BAD , it's working as designed ![](/ubbthreads/images/graemlins/laugh2.gif)
The easiest way to know if it's good or bad is to just ASSuME it pulls timing and use something else.
[Re: JohnRR]
#1437743
06/10/13 12:17 PM
06/10/13 12:17 PM
Posts: 1,319 Ohio
jlatessa
Ohio
OK, I'll buy that response John, so it's a good "street" box, then what would you use as a strip only box that I can jumper wire in a 440, '484' cammed, 906 heads with larger valves, pocket ported, 6 pack, good quench because of new pistons, deck and head cuts, opprox. 10.6 compression, 20D. in the dizzy in at 2000, 1-7/8 hooker super comps, 727 with the looser 383 conv. and 4:10's, WHEW! what a run-on description, sorry. P.S. in a 3800# Charger Joe ![](/ubbthreads/images/graemlins/beer.gif)
[Re: jlatessa]
#1437744
06/10/13 01:23 PM
06/10/13 01:23 PM
383man
Balt. Md
Something that I remembered after reading more on this is how Bill Jenkins used to retard his timing in high gear years back when he ran a points dist. He would cut out one set of points so in high gear and high rpm he retarded his timing. Seems he used alot of advance down low but took some out up top to mph better. I have heard of others doing that also. It does seem that everyone having problems with the orange box have bought them in the last few years and I have heard others say it took timing out as John said. The best thing to do is try another ign and see how it runs. All I can tell you is my 13 year old orange box ran as fast and started as good as the MSD did on my sons car. Ron
