Re: Carter 500's, can this mess be fixed & if so worth it?
[Re: gdonovan]
#1437015
05/15/13 08:20 PM
05/15/13 08:20 PM
Posts: 10,958 Oakdale CT
gdonovan
Oakdale CT
[Re: OzHemi]
#1437018
05/15/13 09:09 PM
05/15/13 09:09 PM
Posts: 1,414 northeast ohio
hulmule
northeast ohio
ask Scott Harms see what he thinks. Probally has same carbs
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
[Re: OzHemi]
#1437019
05/16/13 06:32 AM
05/16/13 06:32 AM
gdonovan
Oakdale CT
Maybe just look around at swap meets, etc for a better couple if you don't want to go to the expense of new?
I'm working under time constraints so waiting for a GOOD pair to show up at a swap meet isn't an option. $250 a pop at Summit is not terrible, but I'd rather put that money towards rims.
[Re: ScottSmith_Harms]
#1437024
05/16/13 01:00 PM
05/16/13 01:00 PM
Posts: 75,282 A gulag near you.
JohnRR
A gulag near you.
I can restore those to look and run as good as new, no problem.
I don't think that's an option at this point?
What's the time from you getting one to shipping it back out? Say something like a new unused Thunder carb to make it look like an original carb ?
#1437026
05/16/13 01:29 PM
05/16/13 01:29 PM
gdonovan
Oakdale CT
If I was doing a restoration Scott you would be the first man I'd call but a restoration isn't required for this little operation ;-)
I'm just looking to put the dual quads back on the GTX, nothing special required. Either I'll get these working or just pop for a pair of remans and sell these off as cores (with full disclosure) to offset some of the cost.
Going to pickup 50 pounds of glass bead from Tractor Supply tonight and see how it goes, nothing to lose. Nothing is bound up, just corrosion in the bowls. The outside of the carbs look better than the insides!
[Re: gdonovan]
#1437028
05/16/13 01:58 PM
05/16/13 01:58 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
When you're done glass beading,make sure you get "ALL" the glass out of everywhere,you will have a nightmare if you don't !
[Re: 62maxwgn]
#1437029
05/16/13 09:22 PM
05/16/13 09:22 PM
gdonovan
Oakdale CT
Oh ya- Soaked in a 5 gallon pail of soap and water, rinsed, blown out, agitated in the bucket again and a final rinse followed with a good carb clean blasting.
The worse one cleaned up nice, one primary jet is being stubborn though. I'm letting it sit overnight soaking in liquid wrench. I might leave it alone since it ran well or I might bang an extractor in the jet and dig it out. I don't like the idea of having one stuck in there.
I didn't get crazy cleaning certain areas since they are just cosmetic interior areas and I wanted to limit the time the unit was in the cabinet.
[Re: gdonovan]
#1437030
05/16/13 09:23 PM
05/16/13 09:23 PM
gdonovan
Oakdale CT
