Re: Tire height for lowered trucks? [Re: 76dodgeboy] #1435940
05/20/13 09:10 AM
05/20/13 09:10 AM
scratchnfotraction Offline
I like the looks of them on the car,I would run it.
when rickster put the 29x15x15 under his truck with the truck axle he used a 10 rim with 7.5 BS.
remember on my truck I have the A-body 8 3/4 and use a 12" wide rim with a 4.5 BS.
I wonder if a 12" wide rim with the 7.5 will fit?
going back to stock springs on mine raised the rear wheelwell a few inches above the tire,so it "could" sick out the fender lip a little with no problems.
Re: Tire height for lowered trucks? [Re: moparpollack] #1435941
05/21/13 11:57 PM
05/21/13 11:57 PM
85086
moparpollack Online penguin-006 OP
Lil Herman
moparpollack  Online Penguin-006 OP
Lil Herman
85086
Snafu 8" wheels are to wide for most 60 series tires.
But took the truck for a drive and it was fun!
SNAFU fixed they sent me 7" wheels so the tire selection is easier now!
Re: Tire height for lowered trucks? [Re: moparpollack] #1435942
05/22/13 10:15 AM
05/22/13 10:15 AM
Germany
1964Polara Offline
1964Polara  Offline
Germany
BTW: how wide where the original steel Rims on a 1979 D150?
7' I guess...
how much Backspace did they have?
I have 255/70 15 at the rear and 215/75 15 at the front.
The rear sits lower than the front. I think I go with 31x10,5 if they
fit on the OEM Steelies....
Re: Tire height for lowered trucks? [Re: 1964Polara] #1435943
05/22/13 11:40 AM
05/22/13 11:40 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
They ran 31s stock on the 4wds so they will fit
Re: Tire height for lowered trucks? [Re: 76dodgeboy] #1435944
05/22/13 11:58 AM
05/22/13 11:58 AM
Germany
1964Polara Offline
1964Polara  Offline
Germany
Ok but do they fit on a lowered truck? After Axle Flip the Rear drops at least 4'
Re: Tire height for lowered trucks? [Re: 1964Polara] #1435945
05/22/13 04:42 PM
05/22/13 04:42 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Lower your truck and put some on and you'll know. I know 30x9.50s for because a member runs them on his Rc
