78 PW CONVERTING LONG BED TO SHORT #1435670
05/13/13 10:51 AM
05/13/13 10:51 AM
SO ILL
K
KISSFANN1 Offline OP
K
SO ILL
I HAVE A CHANCE TO PURCHASE A RUST FREE LB.
CAN IT BE CONVERTED EASILY TO A SB?
78 PW
THANKS,
SLD
Re: 78 PW CONVERTING LONG BED TO SHORT [Re: KISSFANN1] #1435671
05/13/13 11:04 AM
05/13/13 11:04 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Easily would be just get a shortbed. Otherwise easily NoFrame needs shortened box needs shortened Rear driveshaft needs shortened. Frame and box need shortened in front and behind the wheels for it to look Stock
Re: 78 PW CONVERTING LONG BED TO SHORT [Re: KISSFANN1] #1435672
05/13/13 11:28 AM
05/13/13 11:28 AM
SO ILL
K
K
SO ILL
SORRY I WASN'T CLEAR.
I WANT TO COVERT A BED FROM A LONG BED TRUCK TO FIT MY SHORTBED FRAME.
YOU CAN THROW A HOUSE CAT THRU MY PRESENT BED.
THANKS,
SLD
Re: 78 PW CONVERTING LONG BED TO SHORT [Re: KISSFANN1] #1435673
05/13/13 12:49 PM
05/13/13 12:49 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Would be a lot of Cut and weld. Please turn off the caps. Yelling is impolite. Thank you.
Re: 78 PW CONVERTING LONG BED TO SHORT [Re: KISSFANN1] #1435674
05/13/13 01:41 PM
05/13/13 01:41 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
WHAT?!?!?! WHAT!?!?!?
Re: 78 PW CONVERTING LONG BED TO SHORT [Re: Golden-Arm] #1435675
05/13/13 02:06 PM
05/13/13 02:06 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
The front and rear half of the bed need material removed. If your a good body guy go for it. If your not and you want it to look good I wouldn't attempt yourself. has to be PRETTY good and straight cuts. might be better to use the longbox for patch panels
Re: 78 PW CONVERTING LONG BED TO SHORT [Re: 76dodgeboy] #1435676
05/13/13 05:25 PM
05/13/13 05:25 PM
scratchnfotraction Offline
I cut the long bed floor down and replaced the floor in a short box on my 88 440 truck build.
trick is to find a short box with good side slabs first.
I drilled all the spot welds out and replaced the front bulk head and made 2 cuts along the front and rear of long bed floor shinking it down into the short box floor.
this kept the gas fill bulge and tubs in correct position. I did shave the gas door on the outside of the box for a clean smooth slab side look.
i also cut and add the LB set of stock tubs to 1/2 stock tubs in the short bed to tubbed it flush with the frame.
if you plan to cut the side slabs/box down on each end.. I say good luck! thats a lot of time and body work
I am not saying it can not be done,but for the effort/$/time/materals you would be way ahead of the game finding a rotted short box to patch up.
Re: 78 PW CONVERTING LONG BED TO SHORT [Re: scratchnfotraction] #1435677
05/13/13 05:26 PM
05/13/13 05:26 PM
Re: 78 PW CONVERTING LONG BED TO SHORT [Re: scratchnfotraction] #1435678
05/13/13 05:27 PM
05/13/13 05:27 PM
Re: 78 PW CONVERTING LONG BED TO SHORT [Re: KISSFANN1] #1435679
05/13/13 08:36 PM
05/13/13 08:36 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
THANKS,
SLD
Short answer: NO.
