Re: Single vs Dual Master Cylinder [Re: jlatessa] #1435422
05/13/13 09:38 PM
05/13/13 09:38 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I went to a dual M/C right away on my 63 as I knew I was going to race it. I used a stock M/C from a 67 B-body and it fit right on as you can see. I have power drum brakes and it stops fine at the track from 125 mph. Its a good idea to go with the dual as you will have enough brakes to stop if you get a leak in the front or rear system. Ron
Re: Single vs Dual Master Cylinder [Re: Junky] #1435423
05/13/13 09:44 PM
05/13/13 09:44 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Okay guys, after my "debate" Saturday and reading the comments here I'm going to switch over to the dual master. Plenty of good points made for it. Doesn't look like it's going to be much of a job to do it. Thanks for everyones comments.
Good decision Junky! You'd really kick yourself hard if the single pot system let go and you hurt the car or someone else. I get nervous just looking at those single cylinders...
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
