17" year one rally wheel on a 70's truck? #1435053
05/12/13 12:12 PM
05/12/13 12:12 PM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
what do you guys think of the year one 17" rally wheels on a 70's truck? (my 78 shortbox)
if I keep it I want to upgrade the tires and thinking these would look cool on it. only issue is perhaps the backspacing. 17x8 with 4.25" backspacing. think I would have front end issues?
what do you guys think?
Re: 17" year one rally wheel on a 70's truck? [Re: chrisf] #1435054
05/12/13 12:23 PM
05/12/13 12:23 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
as far as looks I'd think it would look good. my main issue with the bigger wheels are when there isn't enough sidewall.
1981 Dodge D150 360 auto
Re: 17" year one rally wheel on a 70's truck? [Re: basketcase] #1435055
05/12/13 12:29 PM
05/12/13 12:29 PM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
I would not put rubber band tires on them. its lowered but still has that big wheel well so would be a 28-29" rear and a 26-27-ish front. I hate the emergency spare tire look
Re: 17" year one rally wheel on a 70's truck? [Re: chrisf] #1435056
05/12/13 12:44 PM
05/12/13 12:44 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
They fit the cars they will fit the trucks. Should look good
Re: 17" year one rally wheel on a 70's truck? [Re: chrisf] #1435057
05/12/13 10:22 PM
05/12/13 10:22 PM
Alexandria,La.
BigTerry Offline
BigTerry  Offline
Alexandria,La.
wow strange looking truck?? when did they build that one?
Re: 17" year one rally wheel on a 70's truck? [Re: chrisf] #1435058
05/12/13 11:00 PM
05/12/13 11:00 PM
houston, tx
d100clubcab Offline
d100clubcab  Offline
houston, tx
Re: 17" year one rally wheel on a 70's truck? [Re: d100clubcab] #1435059
05/13/13 12:49 AM
05/13/13 12:49 AM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
http://gatewayclassiccars.com/displaycar.php?stock=5344&location=STL
36g bet that will never leave. those are 15" so same but different
Re: 17" year one rally wheel on a 70's truck? [Re: chrisf] #1435060
05/13/13 07:15 AM
05/13/13 07:15 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
should look good....a 255/60R17 would be .3" taller than a 235/75R15, a 245/60R16 would be ~.3" shorter.....
for the back, 275/60R17's would look right, and are about 30" tall...
are you afraid the 4.25" backspace won't be enough?
I wonder if you could use LX wheels, which are 5x115mm bolt pattern (vs. 5x114.3mm) and +24mm offset on the 18x7.5" rims (which would be ~5.2" backspace) because these are sharp looking cheap OEM wheels
http://moparonlineparts.com/advanced_sea...n_description=1
and LX's have tire sizes that would look right on a 70's truck....a 235/55R18 is ~28.1" tall
2017 Grand Cherokee Overland
Re: 17" year one rally wheel on a 70's truck? [Re: patrick] #1435061
05/13/13 11:28 AM
05/13/13 11:28 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
I think they would look SWEET! With a 17" wheel on a truck, your sidewall wouldn't be low profile(rubberband).
Re: 17" year one rally wheel on a 70's truck? [Re: chrisf] #1435062
05/13/13 12:08 PM
05/13/13 12:08 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
I think it would look great!
I am a cheapskate, plus I really liked these, so I went this way.
These are 17x8, '03-04 Ram. $100 for the set.
These have a 5 1/2" backspace, and my factory steelies were 4", and with a 255/70/15 rubbed the rear inner well some.
I would have used a 1 1/2" spacer, at the time couldn't find one. I wanted hub centric specifically.
So, I got 2". This moved the sidewall pretty close to the outer fender lip, bed is not perfectly centered, so some adjustment may cure this problem, or roll the lip.
Both only needed if lowering, and carrying weight.
On front I went with 1" spacer, to me is seems perfect, so 4 1/2" backspacing.
A couple inner fender bolts will be replaced with button heads, but only again if I lower it.
Tires are 275/60/17.
What I saved on wheels, after buying spacers and modifying them, I could have bought a set of cheap Summit wheels, but I like these much better.
Obviously on yours the bolt pattern/hub hole would be correct and spacers/adapters not needed.
To summarize, I think the 4 1/2"back space MIGHT be a problem on the rear.
I didn't try the 1" spacers on the back, I think it would be iffy on the inside.
It takes gasoline to interest me.
Re: 17" year one rally wheel on a 70's truck? [Re: VL21] #1435063
05/13/13 01:23 PM
05/13/13 01:23 PM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
Your running P275/60R17 on the front of a 2wd D series? I was always told that they are to big for the front even with stock ride height.
Re: 17" year one rally wheel on a 70's truck? [Re: 98RAM1500] #1435064
05/13/13 04:10 PM
05/13/13 04:10 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Yes, 275/60/17.
At stock height, plenty o clearance.
And I think they will be fine at a couple inches lower, which is all I want.
Not sure if these will show you anything ...
Re: 17" year one rally wheel on a 70's truck? [Re: VL21] #1435065
05/13/13 04:11 PM
05/13/13 04:11 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Sorry, big pics. I'm a dummy, I know.
Re: 17" year one rally wheel on a 70's truck? [Re: VL21] #1435066
05/14/13 09:57 AM
05/14/13 09:57 AM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
265-75-17 tires on 17 x 9 factory SST wheels.
Plenty of sidewall , just what I wanted. Factory tire size for these wheels is 275-60-17 ,
even those are too short for me.
Frank
Re: 17" year one rally wheel on a 70's truck? [Re: duster2] #1435067
05/14/13 10:11 AM
05/14/13 10:11 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Totally wrong truck
Those sizes are within and inch height difference also
Re: 17" year one rally wheel on a 70's truck? [Re: 76dodgeboy] #1435068
05/14/13 07:03 PM
05/14/13 07:03 PM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
Hey VL21 can you take one of the whole truck from the side to see how much they fill the fender wells.
Re: 17" year one rally wheel on a 70's truck? [Re: 98RAM1500] #1435069
05/14/13 07:18 PM
05/14/13 07:18 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Try this one ...
Re: 17" year one rally wheel on a 70's truck? [Re: VL21] #1435070
05/14/13 07:21 PM
05/14/13 07:21 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Need to do a little adjusting I think ...
Re: 17" year one rally wheel on a 70's truck? [Re: VL21] #1435071
05/14/13 08:01 PM
05/14/13 08:01 PM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
Yeah thats it, they don't look to big at all to me, looks good. Im working on a 84 D series, single cab short bed and was kinda of wanting bigger wheels than the 15's but im thinking of a wheel that might stick out maybe a 1/4" to 1/2" more than yours tops, You think they would still clear aright?
Re: 17" year one rally wheel on a 70's truck? [Re: 98RAM1500] #1435072
05/14/13 08:25 PM
05/14/13 08:25 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Stock height you'll be fine with a wider tire/rim. lowered depends on how much lower and if you haul anything.
If your looking at supermarket wheels they usually have a few diff offset/backspacing.
