Page 2 of 3 1 2 3
Re: Challenger - Rear Bumper Guards [Re: CJK440] #143262
08/20/09 11:14 AM
08/20/09 11:14 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
It sounds like you bought 74 rear brackets. The 73 brackets are the same basic design as 70-72...just longer to mount the bumper out farther. 74 used a piece of flat stock for a bracket and there was a large metal box beam thing behind the bumper for it to attach to.
Re: Challenger - Rear Bumper Guards [Re: burdar] #143263
08/20/09 12:17 PM
08/20/09 12:17 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Hmmm,
The brackets I bought definately space the bumper out less than the ones I took off.
The 73 brackets were boxy, similar in construction to these.
the ones I bought look like these.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Challenger - Rear Bumper Guards [Re: CJK440] #143264
08/20/09 12:49 PM
08/20/09 12:49 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
CJK440,
Regarding your questions, the 70-72 bumper mounting bolts are located in the same location.
You do not need to use the filler stip. However, you will have to plug or fill in the retaining holes as a result of removing the filler from your '73. Don't forget you will need to procure a set of the '70-'72 bumperettes or fill in the rear valance gap.
On the front, the '71 bracket is not compatible with your '73 bumper, same as the back.... You have two options. Use the '71 bracket and find a 70-72 front bumper. Or two, redrill your existing bracket per the prior poster's instructions. Use can use your front bumper and merely remove the large bumperettes. Just place a bumper bolt in the holes where the bumperttes were secured. The '70-72 do not have this extra hole.
The only other things that you may want to consider is on the front corners of the 70-72 bumpers are rubber wedges which swedged into the corners on each side of the front bumper. Your '73 does not have them. Perhaps you can add them if if it matters?
Re: Challenger - Rear Bumper Guards [Re: cruzin] #143265
08/20/09 01:09 PM
08/20/09 01:09 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The second picture looks like 74 brackets. They use a large metal piece behind the bumper. If you don't have that extra piece in there...the bumpers wouldn't be out as far.
Anyone else? Am I right or wrong. I thought the 70-72 brackets looked like the first pic. I know 74 brackets are different because member "Challenger1" was going to send me new bumper brackets for my 73. Luckily he sent me pics of his 74 brackets before he sent them.
Re: Challenger - Rear Bumper Guards [Re: cruzin] #143266
08/20/09 01:27 PM
08/20/09 01:27 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
True, you don't HAVE to use the 70-72 filler strip, but as you stand at the rear of the car, by the bumper, and look down, you will see a very noticeable gap without the strip. That why the factory went to the trouble of using the filler strip, and that's the same reason that I did...
I used about 7 self-tapping sheet metal screws to attach my filler to the bottom of the rear end taillight panel. The screw tips protrude slightly into the very lower inside of my trunk, but are not noticeable unless I point them out to someone.
Re: Challenger - Rear Bumper Guards [Re: 318 Stroker] #143267
08/20/09 01:31 PM
08/20/09 01:31 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Here is one of the pics Challenger1 sent me of his 74 brackets.
It's not showing up for some reason but you can see it if you open up the attachment.
Re: Challenger - Rear Bumper Guards [Re: burdar] #143268
08/20/09 02:30 PM
08/20/09 02:30 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
They are similar in construction but definately do not stick up that far.
I just bought a new filler strip and 70-71 bumper. The filler strip will serve to fill the holes from the 73 filler at least.
Re: Challenger - Rear Bumper Guards [Re: burdar] #143269
08/20/09 02:31 PM
08/20/09 02:31 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
74 bumper, I have a rear bumper that I took off a 73 challenger back in 87 or so. It's in my basement and it looks the same as this 74 bumper. It's been 22 years ago so I can't remember if it was a early or late 73. I have more down at a storage bin but they are buried below a ton of stuff, so I couldn't get to them without emptying a 10x15 area stacked to the ceiling. I really need to gather and inventory my stuff all in the same location, yea right that will never happen.
Re: Challenger - Rear Bumper Guards [Re: Challenger 1] #143270
08/20/09 02:35 PM
08/20/09 02:35 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
I'll take some pics of what I got. It looks like the 74 brackets pictured have the bumper mounting tabs roughly parallel to part that bolts to the body.
I think the ones I have definatley have an angle to them, but I could be wrong.
Re: Challenger - Rear Bumper Guards [Re: CJK440] #143271
08/20/09 03:52 PM
08/20/09 03:52 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Heres a pic comparing the two.
Re: Challenger - Rear Bumper Guards [Re: CJK440] #143272
08/20/09 04:45 PM
08/20/09 04:45 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
The lower one in the pic is the 70-71 style...I have a bumper in my shop right now ready to mount on the '71 and those ARE the brackets.
Re: Challenger - Rear Bumper Guards [Re: CJK440] #143273
08/20/09 04:47 PM
08/20/09 04:47 PM
Cincinnati, Ohio
Cincinnati, Ohio
This is a 72 bumper,in the middle. The lower brackets in your picture looks like these I think. So what year are the uppers for in your picture? 73 rear bumper on the left in my picture.
Re: Challenger - Rear Bumper Guards [Re: 318 Stroker] #143274
08/20/09 05:42 PM
08/20/09 05:42 PM
Cincinnati, Ohio
Cincinnati, Ohio
Besides, the 70-72 bumpers have holes in different locations than the 73-74, and there are no holes for the guards...
I don't think this is a true statement, I bolted 70 garuds on my 74 without drilling any holes, filled the extra holes with chromed bumper bolts. See this old thread.
web page
Re: Challenger - Rear Bumper Guards [Re: superwrench] #143275
08/20/09 05:43 PM
08/20/09 05:43 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Joe
65 Barracuda
70 Challenger
Re: Challenger - Rear Bumper Guards [Re: jrwoodjoe] #143276
08/20/09 05:45 PM
08/20/09 05:45 PM
Cincinnati, Ohio
Cincinnati, Ohio
Joe
Aren't the 72s the same as 70-71?
Re: Challenger - Rear Bumper Guards [Re: Challenger 1] #143277
08/21/09 07:54 AM
08/21/09 07:54 AM
Cincinnati, Ohio
Cincinnati, Ohio
Joe
Re: Challenger - Rear Bumper Guards [Re: Challenger 1] #143278
08/21/09 09:22 AM
08/21/09 09:22 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I thought the 70-72 were the same...but I also thought they were a stamped steel part like the 73's so I don't think I will be much help. Sorry for passing on wrong information.
I was told on another site that the 74 bumper guards were bigger than the 73's...also that the rubber piece that extends down to the valence is all one piece in 74 unlike the 2 piece design of 73. Can anyone confirm this?
Re: Challenger - Rear Bumper Guards [Re: burdar] #143279
08/21/09 10:06 AM
08/21/09 10:06 AM
Cincinnati, Ohio
Cincinnati, Ohio
Looky what I found, it adds to my confusion. I'm 98% sure these are the rubber bumpers I took off my 74 about 15 years ago. They appear to be the short ones?
I'm 90% sure this is the bumper I removed from a 73 car that I had in the 80s. Strangly it has one longer rubber bumper on it and one smaller rubber bumper. So I'd say there were long and short bumpers, I would think the longer ones go on a later car(74) but like I said the ones that came off my 74 car appear to be the shorter ones.
Short one:
Longer one on the same bumper, I guess someone changed it before I got the car.
I haven't found the brackets for the 73 bumper yet, so I can't tell what belongs on there as far as brackets go.
Re: Challenger - Rear Bumper Guards [Re: Challenger 1] #143280
08/21/09 10:58 AM
08/21/09 10:58 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Are the pieces that go down to the valence incorperated into the rubber bumpers on the longer ones?
How good is the rubber on the shorter ones. Mine are cracked right throught the middle of the bolt holes.
Re: Challenger - Rear Bumper Guards [Re: burdar] #143281
08/21/09 01:01 PM
08/21/09 01:01 PM
Cincinnati, Ohio
Cincinnati, Ohio
I was wrong again as usual. I guess the bumper in my previous pictures was a 74 with the rear bracing like it is. You were right in the 73 being different than the 74. This is the 73 bumper I cut off a rusty 73 back in the 80s. It has the 73 only brackets on it with the short rubber bumpers. I remembered it as soon as I saw how rusty it was. Unfortantly the brackets are really rusty where they can't be reused. Burdar, PM me your shipping address and I'll send you the short rubber bumpers in my earlier picture as they are in pretty good shape. N/C You just send me whatever the shipping is, if you want them.
There's rust holes in the brackets, I bought this car for 100 bucks and put one of my 340s in it and drove it for a couple years till it got so rusty it wasn't safe anymore. I cut it up in my back yard and put a little out for trash each week. I got rid of the whole car like that, in the weekly trash!
Just a glimpes of one of my storage bins, haven't seen some of this stuff for years.
Page 2 of 3 1 2 3
