Page 2 of 3 1 2 3
Re: 76 D100 lowering project before and after pictures. [Re: BulletBob] #1432232
05/09/13 09:58 PM
05/09/13 09:58 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
Spindles are $238 shipped to the door
Perches & u bolts another $65
Tie rod ends & sleeves are $60
Offset upper bushings are $45
Welding perches $75
Alignment $100
I lowered mine & rebuilt the brakes everything new as well all the suspension for less than $800
dumb question but why 2 sets of perches?
Re: 76 D100 lowering project before and after pictures. [Re: 72d100] #1432233
05/09/13 10:15 PM
05/09/13 10:15 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Welding perches=labor to weld them
Re: 76 D100 lowering project before and after pictures. [Re: BulletBob] #1432234
05/09/13 10:16 PM
05/09/13 10:16 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
okay my bad
Re: 76 D100 lowering project before and after pictures. [Re: BulletBob] #1432235
05/09/13 11:19 PM
05/09/13 11:19 PM
houston, tx
d100clubcab Offline
d100clubcab  Offline
houston, tx
Welding perches $75
Alignment $100
I know $870 is not $1,000 but in my mind it might as well be (when I'ms spending it NOT receiving it)
and your list includes things i totally forgot about like alignment and new bushings.
i just replaced every single front end bushing in my front end 3 months ago!
lowering requires different tie rods and UCA bushings? (i still have to read up on this some more)
but today my front brakes started squealing and my rear cylinders are leaking so i need a complete brake system
luckily rockauto has a lot of brake components on closeout right now so maybe i can get a complete system (rotors, drums, pads, shoes, etc) for under $300
Re: 76 D100 lowering project before and after pictures. [Re: d100clubcab] #1432236
05/10/13 01:18 AM
05/10/13 01:18 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Here's what I got for cheap
Van Lca's
Stock springs
Rear flip
Offset tire sizes
Re: 76 D100 lowering project before and after pictures. [Re: BulletBob] #1432237
05/10/13 08:10 AM
05/10/13 08:10 AM
houston, tx
d100clubcab Offline
d100clubcab  Offline
houston, tx
Van Lca's
Stock springs
Rear flip
Offset tire sizes
I likes that Bob!!!
That's something I can do without thinking about it
I already have brand new stock springs
Rear flip is FREE (or maybe a few new grade 8 bolts) right?
van LCA are going for what in junk yards these days?
can you give me your tire/wheel sizes?
I don't want to scrub my frame every few blocks
Re: 76 D100 lowering project before and after pictures. [Re: d100clubcab] #1432238
05/10/13 09:50 AM
05/10/13 09:50 AM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
The Dakota Dropped spindles also require different rotors due to bearing size differences, different outer tie rod ends, and different adjusting sleeves. The upper control arm bushing do not need to be replaced unless the offset bushing are needed for alignment. I did not use the off set upper control arm bushings on mine, with the Dakota spindles the alignment came into spec fine. \
Too expensive? You need a different hobby then..
Re: 76 D100 lowering project before and after pictures. [Re: jstollfu] #1432239
05/10/13 10:27 AM
05/10/13 10:27 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Bearings are the same as the fullsize. you can use your rotors
Re: 76 D100 lowering project before and after pictures. [Re: jstollfu] #1432240
05/10/13 10:42 AM
05/10/13 10:42 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
How it sits now.
Looks great
I'm going to drop my 89
I try to keep all this info straight but, everyone seems to have different opinions then
My mind gets cluttered
I want to change the bolt pattern to 4 1/2 too
Re: 76 D100 lowering project before and after pictures. [Re: 76dodgeboy] #1432241
05/10/13 11:57 AM
05/10/13 11:57 AM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
No, that is an INCORRECT STATEMENT in my application, a 76 D100, I had to change the rotors due to the rear bearing. (The big one) being a different size. I wanted to keep my 5 on 4.5 bolt circle. Possibley different on other applications.
Re: 76 D100 lowering project before and after pictures. [Re: jstollfu] #1432242
05/10/13 01:29 PM
05/10/13 01:29 PM
houston, tx
d100clubcab Offline
d100clubcab  Offline
houston, tx
just got caught in flash floods here in houston
waves going over the top of my hood as high as my truck stands now
i have about 14 inches of clearance at the lowest point
and things weren't looking so good at times
i can only imagine what would have happened if my truck was lowered
nah, a simple situation like that has convinced me to leave my truck as it is and use it as a TRUCK
high gas prices be damned!
Re: 76 D100 lowering project before and after pictures. [Re: jstollfu] #1432243
05/10/13 07:27 PM
05/10/13 07:27 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
You could have simply used 80-84 2wd Rotors
Re: 76 D100 lowering project before and after pictures. [Re: 76dodgeboy] #1432244
05/10/13 10:10 PM
05/10/13 10:10 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
There's a individual bearing & individual race that converts the early rotor
I have the #'s wrote down in one of my notebooks
Re: 76 D100 lowering project before and after pictures. [Re: BulletBob] #1432245
05/11/13 01:15 AM
05/11/13 01:15 AM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
If you are using dakota spindles 77 new yorker rotors and bearings interchange also.
Or 84 rotors are the same bearing sizes as dakota
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: 76 D100 lowering project before and after pictures. [Re: jstollfu] #1432246
05/11/13 10:29 PM
05/11/13 10:29 PM
libby mt
lifted85 Offline
lifted85  Offline
libby mt
How it sits now.
man I like the stance of the truck did it sit the same way with the cut spring's?? im going cheap on my 81 d150 shorty build an doing the rear axle flip an chopping a coil or 2 up front tell fund's allow for a better set up for the front
drive fast, drive hard, DRIVE MOPAR
Re: 76 D100 lowering project before and after pictures. [Re: lifted85] #1432247
05/11/13 11:49 PM
05/11/13 11:49 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
How it sits now.
At least do the van Lca's
You can use a 255/70/15 on the rear & a 225/60/15 in the front to level it out
Another member asked what size rim
Original 15X7 argent slot wheels with all original caps & trim bands
Re: 76 D100 lowering project before and after pictures. [Re: 76dodgeboy] #1432248
05/13/13 10:37 AM
05/13/13 10:37 AM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Yes that is simply what I used. They are the same part number as the Newyorker rotors. So I've said this at least twice before, in my application to use the Dakota spindles I had to change rotors. I could not use the original 76 D100 rotors with the Dakota spindles. Does that sink it yet? Josh-
Re: 76 D100 lowering project before and after pictures. [Re: jstollfu] #1432249
05/13/13 11:43 AM
05/13/13 11:43 AM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
we really just need to make a list of how to lower these trucks and the parts needed and sticky it
Re: 76 D100 lowering project before and after pictures. [Re: jstollfu] #1432250
05/15/13 11:39 PM
05/15/13 11:39 PM
libby mt
lifted85 Offline
lifted85  Offline
libby mt
The rear is an axle flip with a one inch lowering block.
The next task will be C notching and boxing in the rear frame. Since the rear shock mount attaches to the inside of the frame in the same area the notch will go, I'm going to have to shorten the upper shock mount. Any one have photos of how they C notched their frame. I have a good idea how I'm going to do it but I'd like to see how others did it?
where did ya get ur spring plates from?
Re: 76 D100 lowering project before and after pictures. [Re: lifted85] #1432251
05/16/13 12:02 AM
05/16/13 12:02 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Speedway motors sells some. I think a member on here used theirs.
Page 2 of 3 1 2 3
