Re: 76 D100 lowering project before and after pictures.
[Re: BulletBob]
#1432232
05/09/13 09:58 PM
05/09/13 09:58 PM
Posts: 3,235 Marion Illinois
72d100
Marion Illinois
Spindles are $238 shipped to the door Perches & u bolts another $65 Tie rod ends & sleeves are $60 Offset upper bushings are $45 Welding perches $75 Alignment $100
I lowered mine & rebuilt the brakes everything new as well all the suspension for less than $800
dumb question but why 2 sets of perches?
[Re: BulletBob]
#1432235
05/09/13 11:19 PM
05/09/13 11:19 PM
Posts: 22 houston, tx
d100clubcab
houston, tx
I know $870 is not $1,000 but in my mind it might as well be (when I'ms spending it NOT receiving it) and your list includes things i totally forgot about like alignment and new bushings. i just replaced every single front end bushing in my front end 3 months ago! lowering requires different tie rods and UCA bushings? (i still have to read up on this some more)
but today my front brakes started squealing and my rear cylinders are leaking so i need a complete brake system luckily rockauto has a lot of brake components on closeout right now so maybe i can get a complete system (rotors, drums, pads, shoes, etc) for under $300
[Re: BulletBob]
#1432237
05/10/13 08:10 AM
05/10/13 08:10 AM
d100clubcab
houston, tx
Here's what I got for cheap
Van Lca's Stock springs Rear flip Offset tire sizes
I likes that Bob!!! That's something I can do without thinking about it I already have brand new stock springs Rear flip is FREE (or maybe a few new grade 8 bolts) right? van LCA are going for what in junk yards these days?
can you give me your tire/wheel sizes? I don't want to scrub my frame every few blocks
[Re: jstollfu]
#1432239
05/10/13 10:27 AM
05/10/13 10:27 AM
Posts: 8,064 Iowa
76dodgeboy
Iowa
The Dakota Dropped spindles also require different rotors due to bearing size differences, different outer tie rod ends, and different adjusting sleeves. The upper control arm bushing do not need to be replaced unless the offset bushing are needed for alignment. I did not use the off set upper control arm bushings on mine, with the Dakota spindles the alignment came into spec fine. \
Too expensive? You need a different hobby then..
Bearings are the same as the fullsize. you can use your rotors
[Re: jstollfu]
#1432240
05/10/13 10:42 AM
05/10/13 10:42 AM
Posts: 34,886 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
How it sits now.
Looks great
I'm going to drop my 89
I try to keep all this info straight but, everyone seems to have different opinions then
My mind gets cluttered
I want to change the bolt pattern to 4 1/2 too
[Re: jstollfu]
#1432243
05/10/13 07:27 PM
05/10/13 07:27 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
No, that is an INCORRECT STATEMENT in my application, a 76 D100, I had to change the rotors due to the rear bearing. (The big one) being a different size. I wanted to keep my 5 on 4.5 bolt circle. Possibley different on other applications.
You could have simply used 80-84 2wd Rotors
[Re: BulletBob]
#1432245
05/11/13 01:15 AM
05/11/13 01:15 AM
Posts: 1,652 Amarillo, Tx
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
If you are using dakota spindles 77 new yorker rotors and bearings interchange also. Or 84 rotors are the same bearing sizes as dakota
84 D150 440/727 79 /6 swb D150 1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
[Re: lifted85]
#1432247
05/11/13 11:49 PM
05/11/13 11:49 PM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
How it sits now.
man I like the stance of the truck did it sit the same way with the cut spring's?? im going cheap on my 81 d150 shorty build an doing the rear axle flip an chopping a coil or 2 up front tell fund's allow for a better set up for the front
At least do the van Lca's You can use a 255/70/15 on the rear & a 225/60/15 in the front to level it out
Another member asked what size rim
Original 15X7 argent slot wheels with all original caps & trim bands
[Re: 76dodgeboy]
#1432248
05/13/13 10:37 AM
05/13/13 10:37 AM
Posts: 271 Dearborn, Michigan
jstollfu
Dearborn, Michigan
Yes that is simply what I used. They are the same part number as the Newyorker rotors. So I've said this at least twice before, in my application to use the Dakota spindles I had to change rotors. I could not use the original 76 D100 rotors with the Dakota spindles. Does that sink it yet? Josh-
