Re: 99 2500 Diesel, tranny slipping/throttle position senso
[Re: N9671X2]
#1431473
05/07/13 03:15 PM
05/07/13 03:15 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
A friend of mine had a problem with his and it turned out to be the computer. This was after having the trans rebuilt.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: John_Kunkel]
#1431475
05/07/13 03:26 PM
05/07/13 03:26 PM
Posts: 75,047 U.S.S.A.
JohnRR
U.S.S.A.
I know it sounds dumb, but I am not completely sure it was slipping,
Your tachometer will tell you if it's slipping or if the converter is cycling.
What gear was it in when it was supposedly slipping ? How does your reverse engage ?
Put a load on it and you'll find out if it's slipping or not.
Foot to the floor thru all the gears , if it's slipping it will tell you.
