Re: Exhaust Flame throwers who has done it and made it work
[Re: HealthServices]
#1430537
05/05/13 08:33 AM
05/05/13 08:33 AM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
I have a setup somewhere at the other garage.Its transistorized and runs to spark plugs in the tail pipes.Took it off one of the sons friends cars.It worked pretty good when he had it hooked up.Other than that I have no idea.Rocky
Chrysler Firepower
#1430544
05/05/13 05:45 PM
05/05/13 05:45 PM
Posts: 4,812 Castlegar, BC, Canada
That AMC Guy
ok because I seem to have spark at the plug in the exhaust, and when I push the the switch it kills spark to the engine. I'm assuming, here is the part where theory and realty don't seem to work together, that the motor is pumping fuel and gas into the exhaust and the spark plug is suppose to fire the mixture in the exhaust?
You're supposed to rev up the engine, THEN push the button to deactivate your ignition and activate the spark plug at the tail pipe. Keep your foot firewalled and the carb will dump raw fuel into the engine. The still spinning engine will push that raw fuel into the exhaust and the plug near the tail pipe will ignite the gasses.
I've seen it done on a 6-cylinder Hudson!
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
[Re: That AMC Guy]
#1430546
05/05/13 07:22 PM
05/05/13 07:22 PM
Posts: 15,487 Florida
scratchnfotraction
this is what I have seen and what my son had on his jeep.
what i dont get is how in the movies they light the pipes and blow flames as the drive off.
IIRC the movie grease and Macon County Line have the cars doing it.
grease was the black led sled and MCL was a yellow 57 chebby. ![](/ubbthreads/images/graemlins/shruggy.gif)
If I was to have one I would want to light it as I drove off from a stop light. ![](/ubbthreads/images/graemlins/drive.gif)
anyone know how this kind of flamethrower work? ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: RalleyA12]
#1430548
05/06/13 05:05 PM
05/06/13 05:05 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I'm going to try a different direction and try wiring it like this... ![](/ubbthreads/images/graemlins/luck.gif) Well the jumper did not allow the the ignition to cut out so I removed it.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
#1430551
05/06/13 08:45 PM
05/06/13 08:45 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
killing the engine with the RPM up and the throttle wide open seems like the lazy way to do it to me.... if one REALLY wanted to do this, why not just plumb a nitrous jet to the exhaust with an auxiliary fuel pump, when you want to light them off, hit a button...activate the NOS solenoid (no funny gas, just gasoline) you get fuel to spray into the exhaust near the tips, and a spark plug to light it off. that way you can keep your engine running, you don't kill your rings with raw gas washing away the oil, and you get to throw flames while driving away. ![](/ubbthreads/images/graemlins/shruggy.gif)
**Photobucket sucks**
[Re: 70Cuda383]
#1430552
05/06/13 08:58 PM
05/06/13 08:58 PM
Posts: 7,759 So Cal
HealthServices
So Cal
maybe later on this one... I have solenoids and such but a little afraid of showering fuel on the truck and having it ignite... afterwards! ![](/ubbthreads/images/graemlins/panic.gif)
Allen
[Re: That AMC Guy]
#1430553
05/09/13 06:47 AM
05/09/13 06:47 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
Pfffft!! I had a 70 Buick that would do this without ANY mods... Sorta like the Uncle Buck car... but with fire.
