Re: New engine dyno numbers???? E street [Re: Thumperdart] #1429709
05/04/13 01:02 PM
05/04/13 01:02 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
As slow as my hands have become, apparently they are faster than my brain.
Re: New engine dyno numbers???? E street [Re: BSB67] #1429710
05/04/13 01:18 PM
05/04/13 01:18 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I generally say and do things that leave people wondering what the hell is goin on in my cranium...........
Re: New engine dyno numbers???? E street [Re: Thumperdart] #1429711
05/04/13 05:27 PM
05/04/13 05:27 PM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
Isn't the combustion chamber in the head the same as the bowl?
Re: New engine dyno numbers???? E street [Re: demon440] #1429712
05/05/13 09:18 PM
05/05/13 09:18 PM
CT
440Kilmartin Offline OP
CT
Sure
Re: New engine dyno numbers???? E street [Re: demon440] #1429713
05/06/13 12:07 AM
05/06/13 12:07 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Bowl is up stream from the valve .....towards the carb on intake , exh on exh.
The typical choke point in a lot of heads and where big gains can come from when porting.
Chamber = pocket on combustion face of cylinder head deck area where valves & spark plugs hide.
Re: New engine dyno numbers???? E street [Re: 440Kilmartin] #1429714
05/06/13 03:05 AM
05/06/13 03:05 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Cool Mike, I remember meeting you up at the Heavenly Donut in Derby. You built your stoker. Was that 833 an 18 spline?
Re: New engine dyno numbers???? E street [Re: GTX MATT] #1429715
05/06/13 03:12 AM
05/06/13 03:12 AM
CT
CT
Ya the old motor was just an old truck motor. nothing fancy. Shoul be interesting with a new 500 stroker and stock 23 spline lol ......... Hmm I trying to remember ... What car did u bring to The doughnut
Re: New engine dyno numbers???? E street [Re: 440Kilmartin] #1429716
05/06/13 12:18 PM
05/06/13 12:18 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Mike I probably didn't have a car with me since mine has been out of commission for about 2 years now (for about another month or so only, hopefully!) but I've got a gold '67 Satellite with a 440/4 speed.
Good luck with the 23 spline. I'm going to be pushing one soon too with my stock stroke 440, looking to be around 550 hp so I'll be a bit safer than you with the stock stroke and less torque, but still looking to put the hurt on it (and the 8 3/4 behind it). I've got 3 so I'm prepared to break one, trying to trade up for an 18 spline though.
You did have a 4.10 Dana though as I recall. You running a scatter sheild?
Re: New engine dyno numbers???? E street [Re: GTX MATT] #1429717
05/06/13 05:44 PM
05/06/13 05:44 PM
CT
CT
Ya Dana w 410 for now. Probably go with 3.73 soon. It will probably run out of gear at the track.
Re: New engine dyno numbers???? E street [Re: 440Kilmartin] #1429718
05/06/13 06:24 PM
05/06/13 06:24 PM
I'll bet you shift it into 4th about 1000 ft. or so, no where near maxing the RPM out in high gear Of course that all depends on what RPM you shift it at in the other three gears After looking at your dyno print out I would probally try shifting it at 5500 RPM for two runs and then at 6000 RPM and see what the car likes the most
Re: New engine dyno numbers???? E street [Re: Cab_Burge] #1429719
05/06/13 06:50 PM
05/06/13 06:50 PM
CT
CT
Will do . I think 5700 may be best . Hopefully ill find out soon. I don't want to over rev this thing going through the lights.
Re: New engine dyno numbers???? E street [Re: 440Kilmartin] #1429720
05/06/13 07:29 PM
05/06/13 07:29 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
You'll trap about 5600 at 125, plus or minus a few.
