Re: MOPAR 6.1L Hemi GEN III Hemi Aluminum Block
[Re: blown572dart]
#1429128
05/02/13 07:58 PM
05/02/13 07:58 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
I would use a 5.7 block, add a K1 Stroker kit, clean up the heads, reuse a truck intake and add a small 220/220 ish cam. Huge torque and driveability for a little bit more than the block alone.
If you want to do it, buy the alum block. We all understand lol.
Yea the aluminum block is probably which way I want to go. So the search and reading will begin.
BTW it's definitely not for the Dart. Someone else will be playing with it soon enough. ![](/ubbthreads/images/graemlins/stirthepot.gif)
The big question is finding a good gen111 builder
Whats the Goal....????
Rickster
[Re: DusterDave]
#1429134
05/02/13 11:03 PM
05/02/13 11:03 PM
Posts: 5,067 Orlando Florida
blown572dart
Orlando Florida
Rickster
Question number 1 was finally asked.
No major goals. I was going with a ripp but the cost is't worth it when I can do a Hemi for just a bit more ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: DusterDave]
#1429136
05/02/13 11:31 PM
05/02/13 11:31 PM
blown572dart
Orlando Florida
Rickster
Goals like, how much power do you want this engine to make? If you want big power, are you prepared to replace the rest of the drive train? The modification of a Jeep never ends. JEEP stands for Just Empty Every Pocket.
All ready in the works swaping out the axles to high pinion 60s and the trans along with the transfer case will be upgraded at the same time. I am already running aftermarket suspension which will be upgraded to a long arm and possible coil overs. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: blown572dart]
#1429137
05/02/13 11:39 PM
05/02/13 11:39 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Then it sounds like you're ready to go all they way on that thing! I hope you start a build thread! Where are you getting the HP60's from? Currie, or? Are you looking at replacing your stock transfer case with a Atlas?
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: blown572dart]
#1429141
05/03/13 08:05 AM
05/03/13 08:05 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Bes what did he make in the engine masters
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: moparniac]
#1429146
05/03/13 04:51 PM
05/03/13 04:51 PM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
Hemifred probably bought the dart he likes silly stuff
Probably... Geez, what I give to own a car like that ![](/ubbthreads/images/graemlins/drool5.gif)
[Re: Defbob]
#1429147
05/03/13 05:54 PM
05/03/13 05:54 PM
blown572dart
Orlando Florida
![](/ubbthreads/images/graemlins/scope.gif)
