Re: Odometer Reading Vote
[Re: Pacnorthcuda]
#1428821
05/02/13 08:26 AM
05/02/13 08:26 AM
My personal thought would be to keep it with the mileage that it has. Reasoning for this is you might run into a problem if you should ever sell the car and the title not match what the odometer shows and then would have to get a title that says modified mileage or something to that extent.
[Re: BigBlockMopar]
#1428823
05/02/13 10:38 AM
05/02/13 10:38 AM
Posts: 5,048 Atlanta Indiana
Dave Watt
Atlanta Indiana
Indiana law FYI:
Information Maintained by the Office of Code Revision Indiana Legislative Services Agency
IC 9-19-9 Chapter 9. Odometers
IC 9-19-9-1 Advertising, sale, use, or installation of devices causing odometers to misregister mileage Sec. 1. A person may not: (1) advertise for sale; (2) sell; (3) use; or (4) install; any device that causes an odometer to register mileage other than the mileage driven by the vehicle as registered by the odometer within the manufacturer's designed tolerance. As added by P.L.2-1991, SEC.7.
IC 9-19-9-2 Disconnecting, resetting, or altering odometer Sec. 2. A person may not: (1) disconnect; (2) reset; or (3) alter; the odometer of any motor vehicle with intent to change the number of miles indicated on the odometer. As added by P.L.2-1991, SEC.7.
IC 9-19-9-3 Operation of vehicle with disconnected or nonfunctional odometer Sec. 3. (a) This section applies to all motor vehicles except the following: (1) Motorcycles. (2) Trucks the declared gross weight of which exceeds eleven thousand (11,000) pounds. (3) Motor vehicles that have a model year on their registration card that is at least five (5) years earlier than the year the vehicle is in operation on a street or highway. (b) A person may not knowingly operate a motor vehicle on a street or highway if the odometer of the vehicle is disconnected or nonfunctional. As added by P.L.2-1991, SEC.7.
IC 9-19-9-4 Service, repair, or replacement of odometer Sec. 4. This chapter does not prohibit the service, repair, or replacement of an odometer if the mileage indicated on the odometer remains the same as before the service, repair, or replacement. If the odometer is incapable of registering the same mileage as before the service, repair, or replacement, the odometer shall be adjusted to read zero (0) and a notice in writing shall be attached to the left door frame of the vehicle by the owner or the owner's agent specifying the
mileage before repair or replacement of the odometer and the date on which the odometer was repaired or replaced. A person may not knowingly remove or alter a notice affixed to a motor vehicle under this section. As added by P.L.2-1991, SEC.7.
IC 9-19-9-5 Fraudulent violations and omissions; classification of offense Sec. 5. A person who, with intent to defraud: (1) violates this chapter; or (2) omits to do any act that is required by this chapter; commits a Class D felony. As added by P.L.2-1991, SEC.7.
IC 9-19-9-6 Corporate directors, officers, or agents; criminal liability Sec. 6. An individual director, officer, or agent of a corporation who authorizes, orders, or performs any of the acts or practices prohibited by this chapter is subject to criminal liability in accordance with IC 35-41-2-4. As added by P.L.2-1991, SEC.7.
IC 9-19-9-7 Deceptive acts; civil penalties; recovery by attorney general Sec. 7. A person who: (1) violates this chapter; or (2) violates 49 U.S.C. 32709 (as in effect January 1, 1995); commits a deceptive act and is subject to a civil penalty of not more than one thousand five hundred dollars ($1,500) for each violation in addition to other remedies available under this chapter and IC 24-5-0.5. The attorney general, acting in the name of the state, has the exclusive right to petition for recovery of such a penalty, and the penalty may be recovered only in an action brought under IC 24-5-0.5-4(c). As added by P.L.2-1991, SEC.7. Amended by P.L.54-2009, SEC.4.
[Re: AAR#2]
#1428825
05/02/13 10:37 PM
05/02/13 10:37 PM
Posts: 6,017 Salem
Grizzly
Moparts Proctologist
Salem
If it was over 100,000 I would say go back to zero. But, at 76,000 leave it. Your entire resto will be documented at that point anyway. To me, a car with less than 100,000 original miles carries alot of weight, more so than "numbers matching drivetrain". At 76k many of the pieces you take off should be able to be cleaned/polished/painted back up and put back on which (to me) preserves the originality. When I'm buying cars I look for originality and straightness of the body, I could care less if the engine's been swapped 20 times.
Mo' Farts
Moderated by "tbagger".
