Re: Do spoilers work?
[Re: pishta]
#142683
11/02/08 02:06 AM
11/02/08 02:06 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
I heard the old DC spoilers for Dusters actually slowed them at the track.
Ask 340SIX, it has a rear spoiler that faces up....
I wasn't talking rear I meant to say the front one.
[Re: boydsdodge]
#142688
11/02/08 05:32 PM
11/02/08 05:32 PM
Posts: 27,485 So Cal
autoxcuda
So Cal
Thanks for the link AutoXcuda, also sorry to read that your web page is gone. I hope you are able to salvage it. I am going to email the Cuda spoiler guy and see if he has any made up for the Challenger.
If you look at Tom Quad's AAR at watkins glen I think he has a ABS plastic front spoiler. Those are much more durable than fiberglass. They will bend and then bend back. I have seen 67/69 Camaro spoilers adapted easy to various Mopars. Maybe even a 69/70 Mustang one?
Tom Quad where did that spoiler come from?
[Re: autoxcuda]
#142689
11/02/08 05:46 PM
11/02/08 05:46 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
That is a mighty fine lookin chin spoiler on there.
How about the AAR-T/A rear ducktail spoilers? Those seem to have much use at 'normal' speeds?
[Re: GoodysGotaCuda]
#142690
11/02/08 06:37 PM
11/02/08 06:37 PM
autoxcuda
So Cal
I think the basic coupe outline with notchback rear with flat trunk of a E-body is very similar to the 69 Camaro they tested in the 69 Car Life spoiler article. And the Camaro ducktail spoiler is very similar to the AAR/TA. So if it worked on the Camaro I think it will work on the E-bodies.
In the article they got about 50 lbs of force at 70 mph,IIRC. Things just were starting to happen then
[Re: Rug_Trucker]
#142692
11/04/08 05:41 AM
11/04/08 05:41 AM
Posts: 2,592 None
71rm23
None
There are four forces that affect an airfoil.
thrust, drag, lift, gravity.
"Thrust"? Explain
Whatz da matter? Didn't you see "Chicken Run"
These four forces are more related to aviation/aeronautics. Think of thrust as "horsepower", I guess. The amount of force it takes to propel an object.
Gravity Thrust + Drag Lift
Drag tries to counter thrust Gravity tries to counter lift
When thrust and lift overcomes the drag and gravity, you have propulsion
[Re: autoxcuda]
#142693
11/06/08 12:44 AM
11/06/08 12:44 AM
Posts: 102 Round Rock, Tx
PlumCrazyChris
Round Rock, Tx
I found this link, maybe you could make one of these work. The price is sure right.
http://www.up22.com/spoilers.htm
Let us know what you find out.
