for sale
440 max wedge hemi with a stock 3/4 cam and no alt/charging system
gots a cut off switch in the trunk
missing some of the factory smoke that comes in the wires in the dash,they got a leak when I tested the alt
the lights are dim cause its low on the blinker fluid in the master cyl
bring your own batt,mine is blowed up,sorry
its on a hill,I will help push you down it to pop the clutch on the auto tranny
BR549
I have a car for you!
note to myself...undo the batt when running and drive it home tonight,I will post back if it leaks any smoke out
