Re: Torque Converter tech tips..
[Re: gregsdart]
#1423908
04/24/13 12:33 PM
04/24/13 12:33 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
I Am looking forward to your results! Our combos are somewhat similar. What size core did they go with for you? Does ATI use a diode?
The sales rep I spoke with said an 8" might be too loose for the 4.50 stroke... and that we'll have more adjustability with the 9"... So I agreed to the 9" Fuel and Blown converter..
Also, I was told that the phone guys takes the orders and collects the specs, then some TC guru reviews it at ATI to make sure its correct..
As Dustin said above.. we're bracket racers and our goal is to turn on the win light.. more than ET chasing.. So if I can repeat the numbers each run, I'll be happy
