Re: Tubular UCA'S to much?
[Re: brads70]
#1423547
06/01/13 11:46 PM
06/01/13 11:46 PM
moparAL
No, I am not going to buy this item. But what I found interesting and wanted to share with everybody, was the wide range of adjustment. If you read this e-bay sellers other auctions he was offering two versions one used a 1 inch aluminum adjusters and the other auction the UCA used dom .120 steel wall tube adjusters. The way I read it but I could be wrong, one version was using all steel components. Here is a excerpt from that ad.
*built and shipped in stock a-arm specs Up for auction is a pair of fully adjustable control arms (A-arms) for 1962-72 B-body and 1970-74 E-body Mopar, Dodge and Plymouth. Dial in your castor and camber with these homebuilt fully adjustable A arms. Removes unwanted play and excessive movement in the front end by eliminating the rubber bushings. Features in car adjustability high misalignment rod ends, strong DOM .120 wall steel tubes, and ball joint collars (built for racing in IMCA, stock car and NASCAR) upgraded from 3/8" hole to 1/2" hole and fits stock (screw in style) 1968-89 Chrysler K772 ball joints (ball joints not included). Includes steel rod ends and new hardware.
Was it welded around the ball joint collar, obviously. Would it have been better to have been solid billet, yes. But I get tired of seeing Chevy and Ford unique suspension items all the time and when someone comes out with a little different Mopar piece, I think that is cool!
[Re: moparAL]
#1423548
06/02/13 12:59 AM
06/02/13 12:59 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Peter Bergmann on here has some arms like those, SPC I think?, that look WAY better built and offer the same adjustment.
Mopar to the bone!!!
[Re: 72Swinger]
#1423549
06/02/13 01:45 AM
06/02/13 01:45 AM
moparAL
Haven't seen the SPC piece before, but here it is, the SPC upper control arm. It mentions all steel contruction. Doesn't say but looks like standard bushings, NOT A HEIM JOINT, Peter would know. Price retail on the SPC adjustable piece is $482 a pair. The previous posted upper control arms were $270, that is a difference of $212. Just saying this because the topic of this post is Tubular control arms, too much. Here is a exerpt from the SPC ad.
Product Description B & E Body, Passenger Side, Front Upper, Fully Adjustable Style, Steel, Black, Dodge, Plymouth, Each
These SPC Performance street rod and musclecar control arms are available in fully adjustable upper or tubular upper and lower control arm configurations. These arms allow you to fine-tune your suspension to meet your exact needs. Tubular-style arms are available to accept stock, coil-over, and air ride suspensions. Camber, caster, offset, and arm lengths are quickly and easily changed on all adjustable arms.
[Re: mod5v]
#1423551
06/05/13 10:01 PM
06/05/13 10:01 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I have used this style on a dirt race car for years and never had a failure other than a serious hit in the wheel.
Which style?
[Re: SCATPK]
#1423555
06/09/13 02:41 PM
06/09/13 02:41 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
Can someone tell me what the difference is on the arms of a 67-72 a-body vs the 66 and earlier ones?
The 63-67 A-body UCA arms are the same as long as they use the K704 pn ball joint.
The 60-62 A-bodies use a bunch of different suspension pieces and parts. IIRC, they have even smaller UCA ball joints.
