Re: Tubular UCA'S to much?
[Re: Keith Black®]
#1423527
05/14/13 09:31 AM
05/14/13 09:31 AM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
I like others have put off this purchase. I have have a question. All the upper arms that I have seen other than the OEM and FF upper arms have no provision with working with the upper control arm bumper. This may be a stupid question, but how important is this feature?
Our control arm uses upper and lower bump stops.
The Hotchkis UCA's are slick. I'm looking to replace my FF UCA's with these.
DarrenB,
Not questioning your thinking...but want to learn more about these arms.
If you already have FF arms, what is it about the Hotchkis pieces that is so appealing that you would want to change them?
[Re: DynoDave]
#1423529
05/14/13 10:14 AM
05/14/13 10:14 AM
Posts: 841 Santa Fe Springs, CA
Dan@Hotchkis
DarrenB,
Our control arms not only shift the ball joint location like most of the other arms on the market, our re-located pick up point also improves camber and bump curves drastically. That with both the heim joints allows for a fully adjustable setup.
[Re: ScottSmith_Harms]
#1423530
05/14/13 10:20 AM
05/14/13 10:20 AM
Dan@Hotchkis
Some UCA's require notching away sheet metal to install them for clearance (Hotchkis). This is the one reason I won't run them on my car, I only want to add completely reversable upgrades to my car.....
The material removed is minimal; non-structural and not visible once the car is assembled.
![](http://img.photobucket.com/albums/v244/Bajadak/68%20Road%20Runner/100_1234.jpg)
[Re: Dan@Hotchkis]
#1423534
05/15/13 11:31 AM
05/15/13 11:31 AM
Posts: 801 central CT
cudazappa
central CT
IIRC that's only for E-bodies. The A-body UCA doesn't involve any modification.
1971 Challenger
[Re: cudazappa]
#1423535
05/16/13 01:13 AM
05/16/13 01:13 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Now that's something I had not heard! Are you certain of this?
[Re: cudazappa]
#1423538
05/16/13 02:12 PM
05/16/13 02:12 PM
Posts: 27,485 So Cal
autoxcuda
So Cal
The little lip was cut on my A-body for the Hotchkis A-Arms for installation. I have pics I can show later.
I believe it is covered in the instructions if you download and read them.
[Re: jcc]
#1423545
06/01/13 10:03 PM
06/01/13 10:03 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
I don't think I would run those in aluminium.
A new iron curtain drawn across the 49th parallel
