Re: Engine temp how cool is bad ? [Re: JohnRR] #1423151
04/25/13 11:48 PM
04/25/13 11:48 PM
Amherst,NY
challengermike Offline
Amherst,NY
Well for 32 bucks valve seals seam worth a try.
If its not the seals then something must of gone wrong with the rings break in or the pcv is sucking in a lot of oil.
GEZ! Why don't you check out the PCV first??? No $, little effort, easy check?????
He did but the finding seems inconclusive. Wise had a great idea to prove or disprove it being the PCV , put a clear fuel filter in the line and see if it gets filled with oil quickly ???
He's been chasing this problem since last summer .
https://board.moparts.org/ubbthreads/show...rue#Post7299460
Or just disconnect it and run another breather in the hole
Re: Engine temp how cool is bad ? [Re: cjs69mope] #1423152
04/26/13 12:33 PM
04/26/13 12:33 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
sorry to hear about the oil problem, I hope it is not something serious
Anyway, to respond to the original question, yes I do think that is too cool. You want a 180 thermo (if you're not running a thermo, get one in there) and you'd like to see the average temps actually hanging around there. Better oil performance, probably better fuel atomization, drivability, and everything. a cold engine will harm cylinder lubrication and foul the oil quickly
if you have too much radiator in the cold weather, consider blocking a large part of it off like they do with big rigs
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Engine temp how cool is bad ? [Re: VincentVega] #1423153
06/12/13 09:13 PM
06/12/13 09:13 PM
IL . usa
cjs69mope Offline OP
IL . usa
Hey guys i know its been a while like i said it would be , Been putting in to many hours at work.
But i just wanted every one to know how things turned out , the car has been back up and running for 2 weeks .
The problem i have been chasing since last summer was caused by the Teflon hard plastic valve seals i had on my heads.
I was unaware that those were bad for street engines and they started wearing out the guides some have 6 to 8 thou clearance .
so the new seals are a temporary fix i know but the car is not smoking now and seams to have more power .
I also changed the springs because i found the the springs i had were dangerously close to coil bind like less the .060 thou.
My plan is to run it this summer and get fresh valve job in winter to correct the guide wear caused by 5 summers of driving on occasion with those dam Teflon seals.
I just don't under stand why the head manufacture would even put those things on in the first place ?
They trying to save money ? leave them off less damage would have resulted!
Drag motors don't need them if the guides are set up right at least not on exhaust side.
Anyway lesson learned Rubber or Viton for street and drag None and
never Teflon again!
1969 Dodge Charger 1969 Dodge Superbee
Re: Engine temp how cool is bad ? [Re: cjs69mope] #1423154
06/12/13 09:30 PM
06/12/13 09:30 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Great, I just bought a set of these and was thinking, why not just spend 10 bucks more for the viton seals, well Comp says to run these. Another 20 bucks down the drain, in addition to the 20 I spent on the valve spring shims I bought from Comp that are what they recommended and WRONG
Re: Engine temp how cool is bad ? [Re: cjs69mope] #1423155
06/12/13 09:35 PM
06/12/13 09:35 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I can add that I've learned that you need valve covers with at least as good of baffling as stockers and then utilize a pcv with a Steeda oil separator inline between the pcv and vacuum source. I'm gonna epoxy some plate under my valve covers for baffling and do just that. Also for the breather a filtered catch can plumbed from the opposite valve cover is a good idea for when the engine is ran hard so that pressure can be vented without oil as well.
Mopar to the bone!!!
