Re: Tire shake during burnout
[Re: Bad340fish]
#1423119
04/23/13 11:54 PM
04/23/13 11:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Didn't you go from a 6.17 to a 4.10? Thats a huge difference in tire speed if all else is the same.
that is a big change but if he was running a 33" tire and dropped to a 28" thats 103.6 down to 89 so thats part of the difference IF he does change sizes... which I dont know
[Re: Leon441]
#1423120
04/24/13 09:36 AM
04/24/13 09:36 AM
Posts: 13,496 Marion, South Carolina [><]
an8sec70cuda
Leon, we ran into a similar situation w/ the Camaro (436" SBC w/ a glide) I drive for a friend. Had a vibration at about 1/2 track that'd go away on the gear change. Car otherwise ran great, no vibration in the burnout that I could feel though. Turned out to be the front pinion bearing going bad. Changed it and the vibration went away.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: an8sec70cuda]
#1423121
04/24/13 11:06 AM
04/24/13 11:06 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Not sure if I understood the question right,but if its on the burn-out with the Pro-Mods running they might have prep the starting line & track a little better than it was 2 weeks ago.If it is doing it at the end of 1st gear going down the track I would think it was in the drive train,not the tires.A Hi-Horse-Power light weight car can spin the tires & cause a shake,but most times they do it at the torque peak.
PS just for the hell of it jack the rear end up,get you a coffee can tape a piece of soap stone on the top of it and set it close to your rear tires and see if one of your tires has got out of round.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: Leon441]
#1423126
04/26/13 02:24 PM
04/26/13 02:24 PM
Posts: 482 Marysville Wa
moparfan
Marysville Wa
My Olds will shake the tires in the burn out if I don't have enough RPM,i'm referring to doing across the line burnout. If I do my burnout at 6k it will shake the fillings out of my teeth. Not sure if your stationary in the burnout Leon or going across the starting line. I try to keep the RPM around 6500 in the burnout. The car has a 632, glide and 4.10s with a 33 X 16 tire.
2017 Challenger R/T Scat Pack Shaker 2021 T/A 392 1970 Challenger R/T 383,727, 3.55, (Wife's car) 1970 Challenger R/T SE 440-4, 4-speed, 4.10 Dana 1972 Dodge Demon 396 W-2,904, 4.30, 10.660 @ 125.85 2020 Hellcat redeye
[Re: moparfan]
#1423127
04/26/13 11:01 PM
04/26/13 11:01 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
It was happening both ways.
I always start the burnout stationary. When I am in my groove I get the tires rolling then pump the line lock botton so the car can pull out on its own without overrevving.
Once I got in the groove I just ignored the shaking which was reduced because I set the chip at 7,500 to try and elliminate the shake.
Maybe the tires were hot enough and I should have been just pulling ahead.
Leon
[Re: Leon441]
#1423128
04/26/13 11:10 PM
04/26/13 11:10 PM
moparfan
Marysville Wa
Not sure same issue as mine, mine starts the shake because the tires are trying to hook (what if feels like anyway)I lift when it starts doing it. I did have an issue last year, the first time out (prior seasons tires on still) the car shook badly in the burnout and all the way down. I took the tires to the tire shop and they rebalanced them. Shake (vibration) was gone after that. I always leave the car up on the jacks so it surprised me the tires changed over the winter As far as balancing, i've never been lucky enough to not have to balance them, have always vibrated when I didn't.
[Re: moparfan]
#1423129
04/27/13 11:25 PM
04/27/13 11:25 PM
Leon441
Lynchburg, VA
Ran the car today with the 6,17 gear; Very little shake. But, noticed a small vibration momentary in the run.
[Re: Leon441]
#1423130
04/28/13 02:55 AM
04/28/13 02:55 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I would think shocks being worn would be the culprit if the car runs clean down the track. A loose of worn heim maybe.
Mopar to the bone!!!
