need electrical help 73 charger #1421139
04/17/13 07:46 AM
04/17/13 07:46 AM
ontario canada kingston
aspenrt360 Offline OP
Hey guy's out of my depth here with a charging problem. just can't get a charging system problem sorted.new alt. tested and good a couple of known and new volotage regs. tested and good wires tested and good. problem is an overcharge. 13.5 at idle but when revved it goes to 16 almost 17v. revere field wires and it goes back to normal. but wires get really hot. any ideas? car is almost ready for paint and i want this fixed before that . everything on the car works perfect except for the overcharge.
thanks
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: need electrical help 73 charger [Re: aspenrt360] #1421140
04/17/13 08:07 AM
04/17/13 08:07 AM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
Sounds like you may need to check the grounds on the regulator and alternator. Make sure the regulator housing is making good, clean contact to the firewall METAL. You may need the scrape the paint off the mounting holes to get this. Star washers help here.
Do you have the firewall to engine ground strap intalled? With the engine running, measure the voltage between the regulator housing and the alternator case. Since both should be grounded, there should be a negligable voltage drop bewteen the two. If there is voltage between the two, I would check re-check grounds!
Hwck if you have the tools, use a 16 ga or lower jumper wire with alligator clips to connect the VR housing to the neg battery terminal. If this helps the problem, grounding is the problem...try the same with the alternator case..
Grounds will get you every time with these cars!
Re: need electrical help 73 charger [Re: aspenrt360] #1421141
04/17/13 08:14 AM
04/17/13 08:14 AM
Maud,Tx
maud Offline
maud  Offline
Maud,Tx
It doesn't matter which field wire goes on which terminal, the field current just goes though the field windings then back to the reg. The reg sends full field current to the alt, through the field windings, then back to the reg. At this point there is no flow of current, so no alt output. The alt output depends on the amount of field current flow. To get flow the current must go to ground. It goes to ground though the reg case. If the reg isn't grounded good the alt won't work. Try pulling one field wire off alt, the alt should not work, if it does one of the brushes is grounded. Try unbolting the reg with all the wires hooked up. The alt should not work, and the reg case should test hot. If the alt does work I would suspect a field wire grounding issue. If everything checks out good, you have a bad reg. The reg is supposed to limit the amount of current it sends to ground to keep the alt output at 14.5 volts. If it is over that, the reg is bad. Hope some of this makes sense.
Re: need electrical help 73 charger [Re: maud] #1421142
04/17/13 09:12 AM
04/17/13 09:12 AM
the first thing i thought was grounds as well so i cleaned the paint off and even made new ground wires for the voltage regulator and the ign. box. the odd thing about the field wires is when they are on one way i get overcharge the otherway it charges right on spec but the wire gets really hot! i don't want to burn it up.
Re: need electrical help 73 charger [Re: aspenrt360] #1421143
04/17/13 09:21 AM
04/17/13 09:21 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
reversing the wires should of not made the difference in a two wire field alt. so now one of the wires gets hot- there is a internal short on the field coil. take both field wires off. now check each terminal to case ground with a ohm meter. and resistance shown is not good.
to me there is a short in the alt.
Re: need electrical help 73 charger [Re: aspenrt360] #1421144
04/17/13 09:27 AM
04/17/13 09:27 AM
Andrewh Online content
Andrewh  Online Content
so if you are grounded well, you should start checking voltages to see if you are getting drops.
the battery voltage, compared to the sensing line on the vr and one of the field lines that doesn't come from the vr.
see how different they are.
Re: need electrical help 73 charger [Re: Andrewh] #1421145
04/17/13 11:36 AM
04/17/13 11:36 AM
so if i am getting this right the feeling is it is a field wire? or the alt ? i have a spare alt and i did a contiuity test on the field wires and they were good but one could be grounding right?
and thanks guy's for the responses keep em coming.
Re: need electrical help 73 charger [Re: aspenrt360] #1421146
04/17/13 01:44 PM
04/17/13 01:44 PM
Indiana, USA
sandberg Offline
sandberg  Offline
Indiana, USA
if it's not the alt or vregulator it could be your battery. if there is a bad cell or something it could want more of a charge than needed. i had a similar problem where i tried multiple vregulators and a couple of alternators. the alt could also have a short. i would take both the alt and the bat into a store and have them tested.
Re: need electrical help 73 charger [Re: sandberg] #1421147
04/17/13 01:54 PM
04/17/13 01:54 PM
the test should be the field prong on the alternator with no wire attached to the case of the alternator.
see if either has continuity. that is the meter goes to 0 instead of showing an open connection.
if you get that, then your alternator has an internal short.
I don't think this is the case, as you would over charge even at idle.
you could check again with the wires attached, and if you see it go to 0 then you might have a short as you thought in the wires to the field.
again, you need to see how close the voltages you are getting are to battery voltage as well.
one field wire carries 12 volts/battery voltage. the other wahtever the vr gives it.
the vr should also should get 12 volts/battery voltage on the sensing line.
losses occur on that due to the bulkhead connector, the ignition switch and just bad connectors in general.
that would cause the sensing voltage to read less than battery voltage and possibly cause over charging.
you can just jump a line from the battery to the balast(far side from the battery, but you will have to check which one has 12 volts key on) and it should up the voltage to the vr and field wire bypassing the bulkhead and igintion and see if you still over charge.
but that doesn't eliminate the possiblity of bad connectors or a shorted field wire.
Re: need electrical help 73 charger [Re: Andrewh] #1421148
04/17/13 02:18 PM
04/17/13 02:18 PM
thanks again guy's the batt. is new and full charge. the field wire is my target i think. one last question am i right in assuming i can put the field wire on either spade terminal on the alt? what possible problems might that cause?
Re: need electrical help 73 charger [Re: aspenrt360] #1421149
04/17/13 02:43 PM
04/17/13 02:43 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Could be one or other or both.
Yes. When you check continuity on field wire terminals, you want low or no resistance, IIRC (I could be wrong there). BUT, you also want to make sure that there is NO continuity between either one of the field terminals and the case of the alternator (indicating a brush short to the case), that WOULD cause the alternator to charge like mad. And if one brush were shorted to the case, that MIGHT cause the symptoms you described.
I'm no electrical guru, but if I were doing it, I'd try to either get the alternator tested - which might not prove anything other than it can put out it's rated power, which we already know, OR swap in a known good alternator, which would eliminate one source of trouble.
Re: need electrical help 73 charger [Re: MoparMarq] #1421150
04/17/13 03:39 PM
04/17/13 03:39 PM
thanks i had the alt tested yesterday but i also have a known good alt i will try tonight.
Re: need electrical help 73 charger [Re: aspenrt360] #1421151
04/17/13 09:04 PM
04/17/13 09:04 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
check that the brush holder is not shorted to the case.
Re: need electrical help 73 charger [Re: 451Mopar] #1421152
04/19/13 03:38 PM
04/19/13 03:38 PM
wow this is frustrating! last night after much testing and swapping of parts it was perfect 13.2 or so at idle and 14.5 when revved. start it this morning and I get 16.7 at idle! it is like I have a gremlin in there looking to screw me around! I have tried two different alts. three v regs. a new starter relay new ballast resistor cleaned and added grounds sripped and checked all wires. it seems like we have it sorted then it just starts to over charge again. any fresh Ideas?
Re: need electrical help 73 charger [Re: aspenrt360] #1421153
04/19/13 07:09 PM
04/19/13 07:09 PM
Indiana, USA
sandberg Offline
sandberg  Offline
Indiana, USA
i'd take a day or two to be away from it, calm your nerves a bit. if you have a friend have him take a look at it with a fresh perspective. you might go nuts looking at the same thing over and over.
Re: need electrical help 73 charger [Re: sandberg] #1421154
04/19/13 08:30 PM
04/19/13 08:30 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Agreed. Sometimes a good night's sleep helps provide a fresh perspective.
Seems like wiring may be a possible conspirator here. I might check for a possible intermittent short to ground of the wires from VR along harness to alternator. That harness insulation can get pretty hot and crunchy sitting on top of the intake manifold along the passenger side rocker arm cover.
Re: need electrical help 73 charger [Re: MoparMarq] #1421155
04/19/13 09:40 PM
04/19/13 09:40 PM
I'd toss in another known good batt for a quick check of a batt internal issue. Reversing the field wiring makes me think something is awry there with the wiring schematics. I'd take off ALL wiring & with jumper wires with alligator clips termporarily rewire EVERYTHING. Batt positive post to reg "top" terminal and to either alt field terminal. other alt field to other reg "side" terminal. reg case and alt case to batt neg post. engine to batt neg. frame to batt neg. Try your larger regular jumper cables between alt case & batt neg post and alt "batt" terminal to battery positive post.
Re: need electrical help 73 charger [Re: RapidRobert] #1421156
04/20/13 10:24 AM
04/20/13 10:24 AM
I am going to take a look at it early next week. I think I am going to jump everything to see whats what.
Re: need electrical help 73 charger [Re: aspenrt360] #1421157
04/20/13 11:49 AM
04/20/13 11:49 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
adding my two cents based on an experience I got, since pretty much everything has being talked
ONCE I got between 18 and 24 volts depending RPMs, however NEVER got charge. Made a continuity test and everything was perfect.
make it spin it by hand and quite often could feel somekind of step!!! BARELLY able to feel it
Decided to dissasembly the alt to check what it was happening and FOUND one of the stator leads going to diodes bank somekind worn or with signs of friction.
APPARENTLY some of the fan vanes was slightly touching this stator lead. I pushed out the stator lead, reassembly and everything came out nice.
How this happened suddenly ? dunno... was the rotor able to slide into the rear housing ? is posible the front bearing could move back from front housing... This bearing fits into front housing easy without any kind of real pressure just fit tight but if pulleys have somekind of slight missalignment could happen!
Re: need electrical help 73 charger [Re: NachoRT74] #1421158
04/20/13 04:37 PM
04/20/13 04:37 PM
it has happened on two different alternators nacho that is why I have been through all the rest with my buddy who is quite good with this stuff. he is stumped as well! I will try one more alt that I know is good then it is back to the wires.
Re: need electrical help 73 charger [Re: aspenrt360] #1421159
04/23/13 07:58 PM
04/23/13 07:58 PM
ok so I went over everything and it looked and tested fine. so I popped on the new alt I picked up as a spare and bingo right on spec! played with the wires and conections and it stayed steady. odd! well I will try it like this for a bit and see what happens hope it is fixed!
Re: need electrical help 73 charger [Re: aspenrt360] #1421160
04/23/13 09:37 PM
04/23/13 09:37 PM
A certified culture free zone.
74RALLYE Offline
74RALLYE  Offline
When I restored my 74 Rallye I went through 7 bad alternators from Advance Auto. 4 were stripped castings though. After I went to NAPA and got a good alternator I still had an intermittent ground on the voltage regulator. Symptoms were overcharging from the alternator.
Check battery to body, K-frame, engine and firewall ground. I tried to keep the paint pretty on the firewall and run dedicated ground wires. It didn't work out so well. I finally cut the paint and left the dedicated grounds. Now it works.
Re: need electrical help 73 charger [Re: 74RALLYE] #1421161
04/24/13 06:33 PM
04/24/13 06:33 PM
all is well now with the new alt. I probably have the best grounded third gen charger in north America! I have been over every ground on the car. so far so good
Re: need electrical help 73 charger [Re: aspenrt360] #1421162
04/26/13 12:39 PM
04/26/13 12:39 PM
Indiana, USA
sandberg Offline
sandberg  Offline
Indiana, USA
you know i had a similar problem twice and one time it was the alt and i had used two new ones. it had a short, i'm still always leery about my alt so i always keep an eye on my alt gauge. JZ.
