Re: Using old serpentine belts to lift with.......
[Re: DaveRS23]
#1420669
04/16/13 09:16 PM
04/16/13 09:16 PM
Things I would not do. No real life experience needed. 1) Pre-soak my brake pads in silicone to prevent squeeks 2) Use 100 nylon zip-ties on a coil spring because I'm to cheap to rent/buy a spring compresser 3) Lift anything at all with an old cracked worn out serpintine belt. All of the above sound like a good reason people make videos that usually begin with "Hold my beer and watch THIS, Vern!" Not knocking you at all. Do as you please. Even Harbor Frieght sells cheap nylon straps made for the job.
#1420670
04/16/13 09:36 PM
04/16/13 09:36 PM
Posts: 18,427 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Unless you are in competition to be a Darwin star. I used two belts on a pipe to lift a propane tank. Lets just say I wont make that boneheaded move again.
[Re: Diplomat440]
#1420673
04/17/13 01:46 AM
04/17/13 01:46 AM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
i use seat belt alot on stuff that you can't bolt a chain to, never saw a serpentine belt used.
![](/ubbthreads/images/graemlins/iagree.gif) I'm from PA & when I showed the guys the seat belt trick They hoot & hollered "HillBilly Engineering"
They doubted me when I cut the belts out of the MH we were pulling the low mi 360 out of & bolted them to the engine not tied but bound in the factory binder & preceded to lift engine,MH & 2 Big Boys one in each front seat 6" off the ground because they said "Keep going Keep Going"
They are easy to use
[Re: 70Duster]
#1420674
04/17/13 03:21 AM
04/17/13 03:21 AM
Challenger 1
Cincinnati, Ohio
No, I would not use old serpentine belts to lift an engine. A chain or flexible strap made for that purpose is not very expensive. What is interesting about this post is that one of posters here "values his life too much to use a Harbor Freight floor jack", but lifts his large mower with old V belts.
Show me a short enough sling to do what I needed to do and not have the engine hoist jacked up sky high where it's unstable. And the cheap china hoist is very disappointing and what you should be pointing out.
I'd say it's more dangerous than there jacks or the V belt. It's only safe/ok for light duty lifting like in my picture above.
Then a jack stand was used before the blades were changed. A cheap jack is alright if you use jack stands? So tell me what I'm doing wrong other than using a cheap hoist that I wish I never bought. It's so fricken small that you have bend way over to pump the handle, you can tell is was made for a small person in a far away country. It has swivel casters on all four corners, how are you supposed to steer that?
Too many people have never used a decent engine hoist and think that one is the standard nowadays, it's junk!
[Re: wingman]
#1420675
04/17/13 12:30 PM
04/17/13 12:30 PM
Posts: 17,862 albany ny
05dakota
albany ny
It sounds like you have already kind of made up your mind the answer that you want to hear, so why not just go ahead and use them?
I am really curious as to how you came to that conclusion.
Because you argue with every person who tries to advise you not to do it.
exactly
[Re: 05dakota]
#1420676
04/17/13 01:59 PM
04/17/13 01:59 PM
Triple Threat
Renton Washington
My machine shop picked the block out of my truck using the belt off a Jesel belt drive around the main cap. He said its the only way they do them.
[Re: Shoozy]
#1420680
04/17/13 10:41 PM
04/17/13 10:41 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
Could be lots and lots of people that have tried it and failed. However, they're probably still recovering. Just like jumping out the plane without your chute, you're only going to hear from the survivors. My concern would be sharp edges. A simple shift in the load could cut the belt just enough to cause an already questionable (or not) material to fail. That being said,I have seen it done. Never seen it fail but have not seen it done that often. I wouldn't do it if I had a chain. There! Real world experience and opinion. No charge ![](/ubbthreads/images/graemlins/smile.gif)
[Re: DaveRS23]
#1420681
04/17/13 10:45 PM
04/17/13 10:45 PM
DaytonaTurbo
Manitoba, Canada
He read your posts.
[Re: 70Cuda383]
#1420683
04/18/13 08:54 AM
04/18/13 08:54 AM
Challenger 1
Cincinnati, Ohio
That's ok. we know you're a professional who's been doing this for 25 years.
Your not getting any experience sitting at home... ![](/ubbthreads/images/graemlins/hammer.gif)
[Re: wingman]
#1420685
04/18/13 09:19 AM
04/18/13 09:19 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
On the Harley belts.Phil Ross from Super Max developed their belts.I have his belt drive setup on my 58 Panhead.Its super strong and also super light.All the pulleys are a type of plastic with steel inserts.Been on probally 20 years and adjusted one time.Id lift a hemi with his belts.Rocky
Chrysler Firepower
[Re: 62maxwgn]
#1420687
04/18/13 12:21 PM
04/18/13 12:21 PM
Posts: 3,053 Bowling Green, KY
cudaboy
Bowling Green, KY
LOL.
Dennis
[Re: DaveRS23]
#1420688
04/18/13 12:25 PM
04/18/13 12:25 PM
Posts: 2,530 Nunya CA
CR8CRSHR
Nunya CA
Completely stupid and risky idea. After all the rubber has degraded enough that the belt was swapped out from its original use and purpose. It therefore has no tinsel strength and has stretched out because of its original usage. It is just a matter of time before complete failure and either serious or catastrophic injury. Just a bunch of Clowns and Knuckleheads would attempt to do something like this. And I do not care if you can post pics of them being used in such a fashion. It is still freakin...
Another unasked for opinion without any real experience. Complete with insults. Can you not state your position without name calling?
I'll ask you the same question I asked Kevin earlier; why is your inexperienced opinion more important than other people's actual experiences?
What makes you so sure that the belts are outside their useful life? What was their source? In other words, how did you arrive at that opinion? Like you did the other one?
To be perfectly honest, you know NOTHING of the condition or tensile strength of these belts.
Just to be clear here; I have not defended this use of these belts. I am just asking for people's REAL WORLD experiences with them. Good and bad. And it seems that the only people that are afraid of using serpentine belts to lift and pull are the ones that have no experience doing it what so ever. And they are also the same people that appear compelled to call names and sling insults.
Opinionated rants do not convince anyone of anything. That is just arguing, not sharing information.
Oh, and why did you capitalize clowns and knuckleheads?
I put CLOWNS and KNUCKLEHEADS in caps because it is quite evident that only those types of "Jerry Rigging" individuals will try such a maneuver. I think you answered that yourself by your other posts. Need I say more ![](/ubbthreads/images/graemlins/shruggy.gif)
