Living with pump 91 with 10.2.1 BB
#1420505
04/15/13 09:17 PM
04/15/13 09:17 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Ok I run 37 total and 17 initial on my 452 headed 451 with 10.2.1 CR. Car starts with no kick back and after 12 years of running this thing with a 110 octane/pump 91 mix it is where it runs best. Enter last year and I added a FAST EZ efi with the O2 sensor and figure no more leaded race gas and I get ping now lugging it and when rolling into the throttle at anything below 2500 rpm and its all good above 3000 rpm. Running MSD Billet dizzy and MSD Digital 6 box. Been thinking about heavier springs in the dizzy but am afraid im gonna lose the throttle response. Im just frustrated with the quality of fuels these days at the pump, its all pretty crap.
Mopar to the bone!!!
Re: Living with pump 91 with 10.2.1 BB
[Re: 72Swinger]
#1420506
04/15/13 09:28 PM
04/15/13 09:28 PM
Posts: 903 Saskatchewan, Canada
cudabin
I hear you on the poor gas quality... That is why my new 440 Mr Six Pack Attack build is going togehter at 9.5 to 1 compression using 906 heads.
Do you have the manifold exhaust heat crossover blocked? Also are you running a 160 thermostat? Cool is always better to fight knock...
Can you at least get Non-ethanol 91 octane? I believe it will work better. here in Canada, the SHELL 91 has no ethanol, but other 91's do!
Good luck with it.
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: 72Swinger]
#1420508
04/15/13 09:32 PM
04/15/13 09:32 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Its gonna matter on the cam... being that those are iron heads you MIGHT be close but the cyl pressure will tell the store... what is the cranking pressure and the cam specs... if you cleaned any sharp edges in the chambers that will help... also if you can run the coolant temps lower that will help
[Re: MR_P_BODY]
#1420509
04/15/13 09:36 PM
04/15/13 09:36 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
is there a quench pad on those pistons? if they are flat tops, put a closed chamber head on it
I ran my 12-1 engine on 91 at drag week but had the timing turned down to 32 because of that popcorn butter they sell out there
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: d-150]
#1420513
04/15/13 09:51 PM
04/15/13 09:51 PM
MR_P_BODY
what is fuel air ratio.13.7 would be ideal
thats gonna cause more detonation... fuel is a coolant also
[Re: d-150]
#1420514
04/15/13 09:53 PM
04/15/13 09:53 PM
72Swinger
Nebraska
Yep I think it is 13.7-8 at cruise and 13.1 at power. Problem is that is where it says it is but unless I have another o2 sensor gauge who knows.
[Re: d-150]
#1420516
04/15/13 10:03 PM
04/15/13 10:03 PM
MR_P_BODY
asking a question what would be ideal my dyno guy shoots for that number
On a dyno he is shooting for max power... the number comes up to what ever it is.. but it will be in the 12.6-13.0 range... dont ever go for a number when trying to find power... find the power then see what the reading is... cruise is a different matter
[Re: MR_P_BODY]
#1420517
04/15/13 10:31 PM
04/15/13 10:31 PM
72Swinger
Nebraska
I have 2 light silver springs and tried to blue springs yesterday and power was down quits a bit. Might just go with 1 light silver and 1 blue spring and hook up a retard switch that pulls 2 or 3 degrees out. http://setyourtiming.com/images/bwcharts.gif
[Re: 72Swinger]
#1420518
04/16/13 12:37 AM
04/16/13 12:37 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Have you tried just pulling a few degrees out?
I have one 440 (10.12 comp) that would faintly rattle on a hot humid day at 37-38 total. Pulled it back to 34 and it was OK.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#1420519
04/16/13 01:35 AM
04/16/13 01:35 AM
72Swinger
Nebraska
Yeah im also thinkin about changing bushings to reduce total timing a couple degrees. I need to get a new timing light too since my last one disappeared. When I tried the 2 blue springs the thing didnt take off until about 4800 rpm.
[Re: Mopar Guy]
#1420522
04/16/13 12:44 PM
04/16/13 12:44 PM
72Swinger
Nebraska
I will try all the suggestions. The 160 thermostat was tried last year and the car runs cooler with a 180.
