Re: Living with pump 91 with 10.2.1 BB
[Re: 72Swinger]
#1420526
04/16/13 05:53 PM
04/16/13 05:53 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
[I am using NGK xr5s and have been for years.
Arent XR5s the hottest plug NGK makes?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#1420527
04/16/13 06:04 PM
04/16/13 06:04 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I'm not sure but I thought were recommended for 10.1 iron head big block.
Mopar to the bone!!!
[Re: d-150]
#1420529
04/16/13 06:23 PM
04/16/13 06:23 PM
72Swinger
Nebraska
Trying to keep this Big Block Dart at 160 degrees for 5 laps around a road course just isnt gonna happen. So ive accepted the fact that 180-190 is where its gonna be.
[Re: JD Dart]
#1420531
04/16/13 06:43 PM
04/16/13 06:43 PM
72Swinger
Nebraska
Yep I will do some experimenting and follow up what works.
[Re: 72Swinger]
#1420532
04/16/13 07:17 PM
04/16/13 07:17 PM
Posts: 2,885 Pattison Texas
CSK
Pattison Texas
you can use e85 on the ezefi
[Re: Cab_Burge]
#1420534
04/16/13 07:23 PM
04/16/13 07:23 PM
72Swinger
Nebraska
What? Really? Damn so these are a hot plug then? SO a 5670-6 would be next colder then? Yeah im open to reduce the chances of head gasket failure lol!
[Re: MR_P_BODY]
#1420536
04/16/13 08:33 PM
04/16/13 08:33 PM
Von
NE Oklahoma
[ I dont know the NGk numbers but if it is a hot one you most likely will take care of all your problems with a cooler plug... and maybe a touch more fuel
NGK numbers are backwards. The lower the number the hotter. 5 being the lowest and therefore the hottest...
[Re: 72Swinger]
#1420538
04/20/13 09:49 PM
04/20/13 09:49 PM
72Swinger
Nebraska
Update. Changed plugs to the above NGK's and removed Silver bushing for the Black bushing. Replaced one light silver spring with one light blue. Set total timing to 35 and have about 17 intial. Huge difference! I get no ping in 2nd gear matting it at any RPM and just a tad if im lugging it in 3rd and tip in hard in the 1500 rpm range. I feel a bit of relief now that I dont feel like im ruining my engine whenever I drive it.
[Re: Cab_Burge]
#1420540
04/21/13 12:58 AM
04/21/13 12:58 AM
72Swinger
Nebraska
I may just do that Cab. Im betting that when it warms up and air density gets worse it may be fine?
[Re: Blusmbl]
#1420543
04/21/13 11:16 AM
04/21/13 11:16 AM
72Swinger
Nebraska
Ok well I better get some even colder plugs to at least have just in case.
[Re: 72Swinger]
#1420544
04/21/13 02:01 PM
04/21/13 02:01 PM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
I'm running 9.7:1 with a TQ50 Erson cam, flat top KB pistons that are out .009" (oops), ported 452 heads, headers and a torker II intake. All in a 5000lb 4x4. Running a stock distributor with the slots shortened up and the heavy spring removed and, if I remember correctly, 38 degrees total timing. So far I have had zero problems with detonation. Running NGK V-power 7 plugs. I am at 5000 feet in elevation though. I took it to Vegas but had fuel delivery problems so I wasn't exactly hammering on it. It is a 4spd so the load is similar. I do, on occasion, have issues with the plugs fouling slightly at extended low RPM, but they clear up quickly. And by low RPM I mean 600 RPM lugging because I'm too lazy to downshift. Don't know if any of that helps =). I have a set of Stage VI heads I'm porting that will end up on there eventually. Tight quench with a .045" gasket and .009" out should make for a detonation resistant setup in spite of the higher compression. Guess I'll find out.
