Page 2 of 3 1 2 3
Re: HEMI: Intake to Heads Oil Leak [Re: 3ddart] #1420315
04/17/13 09:01 AM
04/17/13 09:01 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Greg,(Superformance) make .030 and.060 gaskets.
Re: HEMI: Intake to Heads Oil Leak [Re: B G Racing] #1420316
04/17/13 12:48 PM
04/17/13 12:48 PM
louisiana
hemi-hunter Offline
hemi-hunter  Offline
louisiana
I use FLATOUT gaskets they come in all port sizes and thickness and will make you custom gaskets if they don't have what you need.
Re: HEMI: Intake to Heads Oil Leak [Re: B G Racing] #1420317
04/17/13 01:37 PM
04/17/13 01:37 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Thanks Bob
Everything is listed in our new catalog.
Click the link in my signature
Re: HEMI: Intake to Heads Oil Leak [Re: roadhazard] #1420318
04/17/13 03:25 PM
04/17/13 03:25 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Thanks Bob
No thanks needed,thank you for some great gaskets and great customer service.
Re: HEMI: Intake to Heads Oil Leak [Re: B G Racing] #1420319
04/17/13 10:24 PM
04/17/13 10:24 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Thanks Bob
Hey Bob, if we didn't offer a great product with competitive prices and great service we'd just be considered a government entity
Re: HEMI: Intake to Heads Oil Leak [Re: roadhazard] #1420320
04/18/13 08:34 AM
04/18/13 08:34 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
With our bailout tax dollars.
Re: HEMI: Intake to Heads Oil Leak [Re: B G Racing] #1420321
04/19/13 09:54 AM
04/19/13 09:54 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
still leaking....when i take the carbs out I can feel "oily gasoline" on the intake to heads joint, and puddling on the intake valves that remain closed....its not just gasoline.
Re: HEMI: Intake to Heads Oil Leak [Re: domingo] #1420322
04/19/13 10:41 AM
04/19/13 10:41 AM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Dom
What heads are you using?
Is it possible to use a valley tray that would seperate the intake and lifter galley.
Old Geezer Racing
Re: HEMI: Intake to Heads Oil Leak [Re: SCATPACK 1] #1420323
04/19/13 10:47 AM
04/19/13 10:47 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I am using a set of the older MP aluminum head castings (not the edelbrocks) with a stage V intake. I have a stock style heat shield under the intake.
Thats it.
I installed it with silicone on both sides and I still can find oily gasoline in there.
I am starting to think it might be sucking oil through the intake port brass sleeves??? These heads got the full porting treatment and blueprinting and the pushrod holes are bushed with bronze sleeves.
Funny thing is I could see oily gasoline on the head to intake joint and also puddling on the intaka valve on one of the ports that has NO PUSHROD SLEEVE showing!...so I dont know if that would be the problem....doesnt seem like it.
Man, now I wish I would have had this engine run on the Dyno before importing it.
I think Im just pullling of the heads to see if the valve guides have the rihgt clearance, check out the valve seals, take a closer look at the heads, reinstall them with new gaskets and check out if the inner valley studs are torqued to 45 lbs. I will but one of those extensions to be able to torque em with my torque wrench to the exact spec, etc.
Re: HEMI: Intake to Heads Oil Leak [Re: domingo] #1420324
04/19/13 10:54 AM
04/19/13 10:54 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
I would look for another issue,it could be a valve, ring or piston problem.If you want to check the gasket seal you can spray a libral amont of light oil(WD-40) in the intake and make plates to cover the carb holes and put an air valve in one,remove all the pushrods to make sure all valves are closed and carefully charge the intake(it only takes a few pounds of air for this).You can view the underside of the intake with a borescope ,mirror or other means for a fine mist if the gaskets leak.This sound like a lot of effort,but it will determine if that or something else is the issue.We had a Hemi that put oil in the intake and it turned out that it had one piston that had detonated and hurt the ring lands and rings.Another thought you might try is put a borescope in each sparkplug hole and check the condition of each piston.
I'am throwing out suggestions since everything you have tried so far hasn't solved your problem.
Re: HEMI: Intake to Heads Oil Leak [Re: domingo] #1420325
04/19/13 12:14 PM
04/19/13 12:14 PM
an8sec70cuda Offline
Did you put thread sealer on the inner row of head studs that thread into the bottom of the intake ports?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: HEMI: Intake to Heads Oil Leak [Re: an8sec70cuda] #1420326
04/19/13 12:57 PM
04/19/13 12:57 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Run it through a couple of heat/cool cycles and re torque or tighten the intake bolts again. then run it again and se if it is still doing it. When you pull the intake and look at the gaskets, do they look oily anywhere on the gaskets? Problem may not be the gaskets if you have tried all of this.
Old Geezer Racing
Re: HEMI: Intake to Heads Oil Leak [Re: domingo] #1420327
04/19/13 01:55 PM
04/19/13 01:55 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I had the same problem and symptoms on a Hemi with those same MP heads. I finally pulled the valve spring off an intake valve and was able to move the valve side ways .004" .005". The guides were way too loose. These were a new set of heads too.
I would think that Modern would catch this on your engine though as that is who fixed mine.
Once the guides were repaired all was good. I have been told the factory guides are oversize and soft.
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: HEMI: Intake to Heads Oil Leak [Re: Hemi Allstate] #1420328
04/19/13 02:46 PM
04/19/13 02:46 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
These heads wereblueprinted , inluding replacing guides if it was needed.
However seeing IM having all these issues IM gonna pull those heads and recheck everything.
Oh BTW, Im thinking....would it be that overtorquing the valley head bolts it would cause the intake port surface that mates the intake manifold to warp and cause sealing issues???
I know that torquing those bolts on alum heads to the cast iron head specs that Mopar reccomends will cause the intake seats to distort and screw up the intake valve sealing.....but could it also distort the intake port surface to the point that it would cause intake to head sealing issues???
I did not torque those heads down, Im clueless about that torque is on those bolts now.....
Re: HEMI: Intake to Heads Oil Leak [Re: domingo] #1420329
04/19/13 06:33 PM
04/19/13 06:33 PM
QLD Australia
Keith Black® Offline
QLD Australia
If you're pulling the heads anyway , get Tim to machine the intake side for O-rings. He's just done my heads I'll post pictures later.
Darren Beale
Keith Black Racing Engines®
Re: HEMI: Intake to Heads Oil Leak [Re: Keith Black®] #1420330
04/20/13 10:37 AM
04/20/13 10:37 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
would be nice, but Im probably as far away from Tim as you are....I dont see myself shipping any parts of this engine back to the states to perform any work on them. I will have to figure it out myself down here....
Re: HEMI: Intake to Heads Oil Leak [Re: domingo] #1420331
04/23/13 03:28 AM
04/23/13 03:28 AM
QLD Australia
QLD Australia
yep I understand Dom. here's some pictures anyway I figured it would be worthwhile as some of the members on here indicated similar problems to what you're having.
hope it works on my build
Darren Beale
Re: HEMI: Intake to Heads Oil Leak [Re: Keith Black®] #1420332
04/23/13 03:32 AM
04/23/13 03:32 AM
QLD Australia
QLD Australia
2
Darren Beale
Re: HEMI: Intake to Heads Oil Leak [Re: Keith Black®] #1420333
04/23/13 10:14 AM
04/23/13 10:14 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
those look great.
I suspect it might be sucking some from the threads on the inner valley bolts. Like Chip suggested Im gonna use some thread sealer in there....
Im also gonna use some penetrating locktite sealer on the pushrod sleeves.
and when the heads are out check vave guide clearance and valve seals...
Re: HEMI: Intake to Heads Oil Leak [Re: domingo] #1420334
04/24/13 09:24 AM
04/24/13 09:24 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
those look great.
Another thing to check is crankcase ventilation,if it's not vented enough or has high crankcase pressure, the crankcase pressure along with cylinder draw can push and pull oil into intakes,bolt threads and other areas that wouldn't normally see oil.
Page 2 of 3 1 2 3
