All im saying is this ignition ( with the little time I have had to play with It!)Seems to work excellent.
Im not really sure why retarding the timing would be an issue if the car runs better with it that way.
You certainly are not hurting anything. I only asked about the vac advance because I wanted to know if I sent The RT Garage $210 was I buying nothing more than a stock ignition with pretty lights on it.
The answer to that is no!
I put it on the car and the car runs much better!
Simple!
If I already did not have the 6AL on the Dart I would put one in that too.
![](/ubbthreads/images/graemlins/Dino2.gif)
