Re: Epoxying Mechanical advance slots
[Re: mrpatel]
#141928
11/02/08 11:24 PM
11/02/08 11:24 PM
cucu, you didn't happen to take any photos of the mods you made did you? I have been watching your post and I am thinking of doing the same. Im glad you got it worked out. Andrew
i didnt take any pics of the plate but I could. i did two plates and one of them was actually broken but I didnt see it before I welded it (I did notice the plate was bent though- turns out it was bent cause it was broken). I could show you what I did.
[Re: thecarfarmer]
#141931
11/03/08 01:54 PM
11/03/08 01:54 PM
no debate. i just cant use it
14" vac at idle in neutral, 5" in gear. that too much change
#141932
11/04/08 09:49 PM
11/04/08 09:49 PM
Posts: 102 Niagara, Ontario Canada
mrpatel
If it is not too much trouble, that would be great. Thank you
[Re: mrpatel]
#141934
11/05/08 08:54 AM
11/05/08 08:54 AM
no trouble at all. I get some for you tonight if i can.
#141935
11/08/08 02:24 PM
11/08/08 02:24 PM
ive been delinquent. I havent taken the pictures yet. I will work on it
[Re: mrpatel]
#141937
11/11/08 12:56 PM
11/11/08 12:56 PM
here are some pics I took. the untouched plate is marked 17 which is 34 degrees total. thats the plat that WAS in my car until I just recently removed it. you can see they slanted the slots to get more advance out of it. Its way to much timing.
The welded plate was the one that was marked 15 (30 degrees total). the slots are milled out to give 14 degrees of total
#141938
11/11/08 12:57 PM
11/11/08 12:57 PM
[Re: bull]
#141942
01/16/09 04:30 PM
01/16/09 04:30 PM
Posts: 15,493 the boonies
aarcuda
the boonies
just bringing this back to the top because it helped me so much that Im sure others here could benefit from it
I agree. Any pics yet?
pics of what?
[Re: mopowers]
#141946
01/17/09 12:03 AM
01/17/09 12:03 AM
Posts: 152 New York
Ken25
New York
here ya go i found the magazine,
dist. degrees X 2 + initial= total
dist. degrees / slot size 6.............. .340 7............... .355 8............... .375 9............... .390 10.............. .405 11.5 ........... .420 12.............. .435 13.............. .445 14.............. .460 15.............. .475 16.............. .490 17.............. .505 18.............. .520
Is this for a BB or a SB? Or both?
Thanks for posting that chart by the way. That'll be nice to have.
