Page 4 of 4 1 2 3 4
Re: anyone here run a 4l80e? [Re: neilaf] #1418648
03/20/15 04:20 PM
03/20/15 04:20 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
We are talking a much higher stall many cars come with just over 2000 so 2800 is close to stock
stock stall speed in that truck is 1400, it now has a 2800 stall converter.
Ok here is another example, how do all the drag week guys not blow up they transmission driving 1000 miles on the interstate with a high stall converter? How does my 4500 converter not kill my 727 in my R/T when I drive it 60 miles on the interstate to the track, race it, then drive it 60 more miles back home??? trans temp never gets over 180 while cruising on the interstate? Ever had a car fell like the transmission is slipping and it turned out to only be a bad tune on the engine?? A torque converter does just that converts torque, when you are on the interstate cruising to torque applied is lower than when you are leaving a stop light.
think aboput a fan blowing another fan to turn it, it is easier to blow the fan when it is already spinning than to blow it moving from a dead stop.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: anyone here run a 4l80e? [Re: slammedR/T] #1418649
03/20/15 04:43 PM
03/20/15 04:43 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Where are you measuring your trans temp?
Sump? Or the line going into the cooler?
Cooler-in will always be a lot hotter and vary more than sump temp.
The thing with converters is they have a slope to their slippage, they aren't on/off, so the slippage is constantly changing due to changes in input/output speed or torque input.
Even if the slip % is the same between 2 sets of operating conditions, if the torque (either input or output) is different, the heat generated is different.
And as the input temperature into a cooler increases, so does its efficiency. So you might add 20° going into a cooler from more slippage, but teh cooler might take 13° of it back out (7° increase on the gauge). But if you add only 10° maybe it only takes 5° out, a 5° increase on the gauge. (hypothetical #s to illustrate my point).
But the bottom line - if it works, it works, and there are then obviously more things going on than just common internet theory.
Re: anyone here run a 4l80e? [Re: Fury Fan] #1418650
03/20/15 06:28 PM
03/20/15 06:28 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I love the mopar 5 speed auto in the 6.1 cars. The new 8 speed sounds like more of a good thing.
Re: anyone here run a 4l80e? [Re: FastmOp] #1418651
03/20/15 06:55 PM
03/20/15 06:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I really like my 518.. I did loose the lock up due to
I wanted a high stall conv.. but the OD is great.. and
its a mech OD with a switch.. I can leave it on all
the time or not and switch it on for the E-way.. with
.69 OD it does drop the rpm which is nice.. 2900
rpm at 75 mph... I do wish I had a bit less slippage
but thats what I get with a 5000 stall on the street
but I do monitor the sump temps but hasnt been a problem
but I need to test in high summer temps.. I have
another cooler with a fan I can put on it if needed
and that would be on a thermo switch for the fan
Re: anyone here run a 4l80e? [Re: MR_P_BODY] #1418652
03/20/15 08:16 PM
03/20/15 08:16 PM
slammedR/T Offline
slammedR/T  Offline
When i still had a built 46RE I was running a Precision Industries "viper" converter for my truck. 3500 stall, twin disc carbon clutch. It was just over a $1,000 but it handled the power and lived under lock-up. I had custom tunes in the truck for different lock-up at different rpm ranges or no lock up at all. If the converter lock-up happened to low in the rpm it would bog the truck down. But on the bottle it like the lock-up a little lower in the rpm than when on motor. On the dyno the lock-up and non-lock numbers was a difference of 40 whp. But I like having the lighter converter without lock-up but when i start making serious power I will want to got to a bolt together lock-up converter.
racemagnum
Re: anyone here run a 4l80e? [Re: slammedR/T] #1418653
03/21/15 03:19 PM
03/21/15 03:19 PM
San Diego
formula S Offline
formula S  Offline
San Diego
Re: anyone here run a 4l80e? [Re: formula S] #1418654
03/22/15 03:52 AM
03/22/15 03:52 AM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
I've got one ready to go behind my small block with a Wilcap adapter. I'll
be controlling it with the megasquirt trans code on a GPIO board talking to a Megasquirt 2 efi controller through CANbus.
Hopefully 20mpg and 600hp.
Re: anyone here run a 4l80e? [Re: sixpackgut] #1418655
03/22/15 01:11 PM
03/22/15 01:11 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
after 3 days of consideration
I have figured my car put 1 million more engine revolutions on it during Drag Week than it would have if I had a .75 OD in it
I also figured out my fuel consumption per engine revolution.
I figured out that the OD should add 3.3 MPG to my current setup
I say that I would drive my car more than I do if it got better fuel mileage but the $300 a year in fuel savings doesn't pay for the cost of the 4l80e swap.
so for me, this trans swap is dead. plan on putting my 426 gen 3 hemi in the car. slap a little carb on it and see what kind of fuel mileage I can get out of it and hopefully make it daily driver capable
Since you have the GV now, are you going to stretch out your oil change intervals too?
If you can't handle the truth, you're living a lie.......
Re: anyone here run a 4l80e? [Re: sixpackgut] #1418656
03/23/15 02:51 AM
03/23/15 02:51 AM
New York
polyspheric Online content
polyspheric  Online Content
New York
I have some ratio data and notes on my site here:
http://victorylibrary.com/mopar/aod.htm
Boffin Emeritus
Page 4 of 4 1 2 3 4
