anyone here run a 4l80e?
#1418588
04/12/13 01:45 AM
04/12/13 01:45 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I'm considering stuffing my Cuda with a 4l80e and wondering if anyone else here has done it already
with a 2.94 first gear and a .74 6th gear, the possibilities seem endless on how well it can work
plus I can swap between a gen 3 hemi and my BB with a simple bell change if I wanted too
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: anyone here run a 4l80e?
[Re: brads70]
#1418590
04/12/13 01:54 AM
04/12/13 01:54 AM
sixpackgut
Charleston
that would be no big deal. my car is a piece of junk anyway. do you use the TCI/fast controller for yours?
[Re: sixpackgut]
#1418592
04/12/13 09:19 AM
04/12/13 09:19 AM
Posts: 13,384 Marion, South Carolina [><]
an8sec70cuda
6th gear? You mean 4th? Or is there some aftermarket version of this transmission that has more gears?
Only 4L80e I had was in my 2500HD truck...it was flawless for 150k miles. I wouldn't use a 4L60e behind anything making decent power. I've blown up 4 of them behind some pretty mild GM LS motors.
[Re: an8sec70cuda]
#1418593
04/12/13 09:32 AM
04/12/13 09:32 AM
sixpackgut
Charleston
oh crap, I thought they were a 6 speed like this TCI http://www.tciauto.com/tc/transmission-packages.html/?main=4
goes to show how smart I am
and the gear ratios I posted are wrong too, lol. I suck
[Re: sixpackgut]
#1418594
04/12/13 09:38 AM
04/12/13 09:38 AM
an8sec70cuda
The 4L80e is basically a big electronic 4 speed overdrive TH400. The 4L60e is comparable to the TH350. The 4L80e is a good trans for what you want to do, it's just physically big.
[Re: sixpackgut]
#1418595
04/12/13 09:54 AM
04/12/13 09:54 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I went with the 518 trans.. basically its a 727 with OD and lock up.. I eliminated the lock up so I could run a high stall regular 727 conv... the 518 has a .69 OD ratio.... and the good thing.. it bolts right up to a small block... they are a heavy trans and its longer than the 727 with the OD in the tail shaft.. if you get one of the earlier ones all you need is a switch to turn on the OD or the lock up if you wanted to keep that... the reason I dumped the lock up is due to the conv.. you cant get a high stall that will have lock up and live(lack of clutch area in the conv)
[Re: MR_P_BODY]
#1418596
04/12/13 10:10 AM
04/12/13 10:10 AM
an8sec70cuda
Will a 727 converter work in the 518 trans? Wondering if I had a 518 w/ an UltraBell on it to fit behind my hemi, could I use my current converter in it? What year 518s only need the switch to turn the OD on? Stupid question...the 518 doesn't need a computer to run it? Sorry for the hijack Ray.
[Re: an8sec70cuda]
#1418598
04/12/13 10:39 AM
04/12/13 10:39 AM
MR_P_BODY
No... the standard 727 and the 518 type pumps use a different drive lug set up... if you change the input shaft and the pump you can use the 727 conv BUT you loose the lock up when doing this(the pump and conv for a 518 have oil paths that turn on the clutch in the conv to have lock up)... there are 2 versions of 518... the late 80s has a single wire plug and the early 90s has a 3 wire plug to control the OD and or lock up... the single wire is what you really want because it was a OD ONLY(no lock up) and the 3 wire has both the OD and lock up but if you want a high stall you nee to change the pump... if you find a 518 that has the 7 pin connector that HAS to use a trans controller(computer controller)... the 1 pin and 3 pin versions are what they call the "H" version.. thats a hyd operated set up.. the 7 pin is called a "E" version(electronic controlled)
[Re: MR_P_BODY]
#1418599
04/12/13 11:03 AM
04/12/13 11:03 AM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
Thats not entirely true - there is a 3 pin 518 that uses a 727 converter ( it's a non lockup version ) and I have it bolted up to an early hemi. I didnt want the lockup or the different converter and this was my best option.
They are hard to find, I forget the specifics , but i found one locally as a core.
[Re: MR_P_BODY]
#1418602
04/12/13 11:51 AM
04/12/13 11:51 AM
DJVCuda
Atco NJ
I'm such a retard!!! It's a 2 pin.... there are 2 pin and 3 pins - the 3 pin ones have lockup. My apologies. I have a 2 PIN - NOT 3 pin - these use the 727 converters and do not have lockup.
[Re: DJVCuda]
#1418603
04/12/13 12:15 PM
04/12/13 12:15 PM
sixpackgut
Charleston
can you get a bell to do the 518 to a big block?
[Re: sixpackgut]
#1418605
04/12/13 12:27 PM
04/12/13 12:27 PM
an8sec70cuda
Yep, there's an Ultrabell for this.
