Something very puzzling happened with my truck #1416982
04/08/13 08:18 PM
04/08/13 08:18 PM
Elk Grove, Calif.
bigblock340power Offline OP
Elk Grove, Calif.
I took it out to do a few errands yesterday. It's a '76 360, auto two BBL. To begin with (a few in town miles) it ran fine (a bit cold, but other wise fine). After I went a few miles, I came to a stop, sat there idling (till traffic cleared), hit the gas, it just died! After I got it restarted, it started running like it was running out of gas (both tanks had gas in them, about 1/2. I even switched tanks a few times). I'd come to a stop and it would die. I'd restart it and it would sputter, then run up ok as I gave it gas in neutral. As soon as I'd put it in gear (on a roll), it would sputter, and barely run again (did this three or four times). I did this a few times. I abandoned my errands and headed (at a limp) for home (just a few miles, a few stop signs, and not knowing if I was going to make it or not). As I got closer to home, it started to run like it should again. I gave it gas, and it started taking it again as it should. Got to the house, and even backed it into the car port. Revved it up a few times in the car port, it did Ok.
Today I put a new fuel pump, and filter on. I'm not sure if this fixed it or not. I haven't had a chance to take it out yet. I did start it up in the car port, and it ran fine (both in neutral, and in gear) for the few minutes I revved on it, and had it running. Very puzzling.
Have any of you out there had one of yours do this? I'm thinking a fuel delivery problem (Carb.?), but could it be electronic, vapor locking (although the fuel lines are not close to anything hot)?
Re: Something very puzzling happened with my truck [Re: bigblock340power] #1416983
04/08/13 08:20 PM
04/08/13 08:20 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
water...I have no idea what your driving other than a truck.
Re: Something very puzzling happened with my truck [Re: Challenger 1] #1416984
04/08/13 08:21 PM
04/08/13 08:21 PM
Cincinnati, Ohio
Cincinnati, Ohio
Thanks for the update....water, my guess.
Re: Something very puzzling happened with my truck [Re: Challenger 1] #1416985
04/08/13 08:25 PM
04/08/13 08:25 PM
Elk Grove, Calif.
Elk Grove, Calif.
I suppose that could be it.
But the tank I run on most of the time is in the cab. Other than condensation, I don't see how water could have gotten into the fuel system. But now that I think of it, the fuel caps are on the side of the body, and it was raining for a few days. Hummmmmm.
Re: Something very puzzling happened with my truck [Re: Challenger 1] #1416986
04/08/13 08:25 PM
04/08/13 08:25 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
How'd the filter look when you took it off?
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Something very puzzling happened with my truck [Re: wingman] #1416987
04/08/13 08:30 PM
04/08/13 08:30 PM
Elk Grove, Calif.
Elk Grove, Calif.
It was a bit harder to blow through than the new one, but I don't think it was that bad.
Re: Something very puzzling happened with my truck [Re: bigblock340power] #1416988
04/08/13 08:38 PM
04/08/13 08:38 PM
Cincinnati, Ohio
Cincinnati, Ohio
You have the filter mounted after the pump, right?
Re: Something very puzzling happened with my truck [Re: Challenger 1] #1416989
04/08/13 08:40 PM
04/08/13 08:40 PM
Elk Grove, Calif.
Elk Grove, Calif.
Yes, between the pump, and the carb.
Re: Something very puzzling happened with my truck [Re: bigblock340power] #1416990
04/08/13 08:42 PM
04/08/13 08:42 PM
Cincinnati, Ohio
Cincinnati, Ohio
Re: Something very puzzling happened with my truck [Re: Challenger 1] #1416991
04/08/13 08:48 PM
04/08/13 08:48 PM
Elk Grove, Calif.
Elk Grove, Calif.
I am starting to like your "water in the tank idea". Because my locking gas caps are not that tight a fit. I think they could let a bit of water in. I'm going to get a couple of stock gas caps for when I have it sitting in the back yard (secure) for long (rainy) lengths of time.
Re: Something very puzzling happened with my truck [Re: bigblock340power] #1416992
04/08/13 09:20 PM
04/08/13 09:20 PM
concerning the water you might take the top off of the carb & see if there's a bunch of water globules in the bottom of the bowl & could take out the idle mix screws & shoot a 2 second blast of starting fluid into each port (need to fit a thin red nozzle straw extension to the spray cap button to get enough in there to flush it out good)
Re: Something very puzzling happened with my truck [Re: bigblock340power] #1416993
04/08/13 10:25 PM
04/08/13 10:25 PM
scratchnfotraction Offline
you can BUY crappy gas with water in it also.
Re: Something very puzzling happened with my truck [Re: bigblock340power] #1416994
04/08/13 10:26 PM
04/08/13 10:26 PM
Cincinnati, Ohio
Cincinnati, Ohio
The 10% ethanol crap gas that they sell us now attracts water now too. Get those filler caps sealed up!
LIke RR said you might want to check your fuel bowls for evidence of water, it'll be laying in there if it's present. Good luck.
Re: Something very puzzling happened with my truck [Re: scratchnfotraction] #1416995
04/08/13 10:27 PM
04/08/13 10:27 PM
Cincinnati, Ohio
Cincinnati, Ohio
Does it cost extra?
Re: Something very puzzling happened with my truck [Re: RapidRobert] #1416996
04/08/13 10:30 PM
04/08/13 10:30 PM
Russ H. Offline
Russ H.  Offline
Just to be safe, I would add a bottle of fuel conditioner/dryer to your tanks. It should take care of any remaining moisture.
Re: Something very puzzling happened with my truck [Re: Challenger 1] #1416997
04/08/13 10:38 PM
04/08/13 10:38 PM
Does it cost extra?
why yes,it did! when this new place open up after the fuel company had been closed a few yrs, they had good price while everyone else was high.
I got 10 gals of gas from them. my truck would barly run,had to flush the fuel cell/lines/filter/pump/carb and refill with gas.
what I did run was !@#$%^ and had droplets of water all under the truck where the exhast dumped,smelled like burning paint thinner.
yea it cost me and a few town folk extra. they dont have many customers nowdays either.
Re: Something very puzzling happened with my truck [Re: scratchnfotraction] #1416998
04/08/13 10:54 PM
04/08/13 10:54 PM
Cincinnati, Ohio
Cincinnati, Ohio
Does it cost extra?
Re: Something very puzzling happened with my truck [Re: bigblock340power] #1416999
04/09/13 12:21 AM
04/09/13 12:21 AM
Riverside, California
ghostrider Offline
ghostrider  Offline
When that happened to my 78 D150 with 318 I found it was a distributor hold down had come loose. Happened on my way to work after 11PM going up a bridge incline. Figured it out after work the next morning, timed by ear and tightened it down and never another hiccup.
Must remember... my humor doesn't work on forums.....my humor doesn't work on forums. Former Mopars include 69 Super Bee, 71 Sebring, 68 Charger, 69 Charger, 78 D150, 67 300, 71 Road Runner clone, 79 T-top Doba, 67 Barracuda, 91 TC by Maserati, 68 Town & Country
Re: Something very puzzling happened with my truck [Re: bigblock340power] #1417000
04/09/13 12:28 AM
04/09/13 12:28 AM
Buy gas from somewhere else for a while and see if it makes a difference. I've ran into this before.
Re: Something very puzzling happened with my truck [Re: bigblock340power] #1417001
04/09/13 12:30 AM
04/09/13 12:30 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
had same problem when fuel line split. The pump would pull a bit of fuel and air at idle/unloaded, but under load could not deliver the fuel volume needed.
