'70 E-Body 4 Speed Reverse Lock Out Linkage..Picture? #141681
10/26/08 03:14 PM
10/26/08 03:14 PM
Anonymous OP
Anonymous OP
Could someone post a detailed picture of all the componets needed for the '70 E-Body 4 speed reverse lock out linkage?I can't tell enough from the parts book or service manual picures.Thanks!!
Re: '70 E-Body 4 Speed Reverse Lock Out Linkage..Picture? #141682
10/26/08 03:35 PM
10/26/08 03:35 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Re: '70 E-Body 4 Speed Reverse Lock Out Linkage..Picture? [Re: Snoopy] #141683
10/26/08 04:00 PM
10/26/08 04:00 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: '70 E-Body 4 Speed Reverse Lock Out Linkage..Picture? [Re: Alaskan_TA] #141684
10/26/08 04:01 PM
10/26/08 04:01 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
2
Re: '70 E-Body 4 Speed Reverse Lock Out Linkage..Picture? [Re: Alaskan_TA] #141685
10/26/08 04:40 PM
10/26/08 04:40 PM
Snoopy Offline
Snoopy  Offline
3
Re: '70 E-Body 4 Speed Reverse Lock Out Linkage..Picture? [Re: Snoopy] #141686
10/26/08 06:01 PM
10/26/08 06:01 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
Snoopy-Do you have the measurement of the cross shaft? Thanks!!
Re: '70 E-Body 4 Speed Reverse Lock Out Linkage..Picture? [Re: 44D6PAKCUDA] #141687
10/26/08 06:24 PM
10/26/08 06:24 PM
Snoopy Offline
Snoopy  Offline
I have don't know where the shaft is, I just moved and I can't find a lot of things. I hate moving.
Re: '70 E-Body 4 Speed Reverse Lock Out Linkage..Picture? [Re: Snoopy] #141688
10/26/08 06:33 PM
10/26/08 06:33 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Man I hear ya there...
I think BEA is repoing the whole lock-out setup..
Re: '70 E-Body 4 Speed Reverse Lock Out Linkage..Picture? [Re: 44D6PAKCUDA] #141689
10/26/08 07:11 PM
10/26/08 07:11 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Is the cross shaft the same between 4 spd and auto?
If so, I have one here from a 1970 340 auto car if it helps. But I would think the small block and big block use different length shafts, Then again, Both a 727's
Re: '70 E-Body 4 Speed Reverse Lock Out Linkage..Picture? [Re: gtx6970] #141690
10/26/08 09:53 PM
10/26/08 09:53 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Completely different..
Re: '70 E-Body 4 Speed Reverse Lock Out Linkage..Picture? [Re: 1_WILD_RT] #141691
10/27/08 01:23 PM
10/27/08 01:23 PM
Snoopy Offline
Snoopy  Offline
The next 3 posts are from the 70-71 Factory Parts Book.
4-Speed
Re: '70 E-Body 4 Speed Reverse Lock Out Linkage..Picture? [Re: Snoopy] #141692
10/27/08 01:25 PM
10/27/08 01:25 PM
Snoopy Offline
Snoopy  Offline
Automatic
Re: '70 E-Body 4 Speed Reverse Lock Out Linkage..Picture? [Re: Snoopy] #141693
10/27/08 01:26 PM
10/27/08 01:26 PM
Snoopy Offline
Snoopy  Offline
3-Speed
