Re: Thumperdart's Photos
[Re: Thumperdart]
#1415325
04/06/13 06:28 PM
04/06/13 06:28 PM
Posts: 939 glendora, ca.
Deepockets
glendora, ca.
cool, finally got to see the details. bakersfield this weekend?
Thinking about next fri. t&t there.............how about you.
no, sorry. i still got the red car in the trailer for the summit series next sunday. they do have the test and tune that day for $20.00. good luck and hope your diet pans out to your expectations. you know i went with the alumn. block for weight savings, then i go and put the throttle stop on it. figure that one out?
[Re: Thumperdart]
#1415326
04/06/13 06:54 PM
04/06/13 06:54 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Good job Dom..I like the simplicty...straightforward and clean..
RIP Monte Smith
[Re: rt66jim]
#1415333
04/06/13 09:41 PM
04/06/13 09:41 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
I like it. Where is the coil mounted.
Under the dash I can see the coil wire going in the fire wall.
[Re: Thumperdart]
#1415336
04/06/13 10:49 PM
04/06/13 10:49 PM
Posts: 808 mckinney texas
shoebox
mckinney texas
So all the interior is new? I like it. Buddy of mine had a stock interior Completely covered in gray tweed. Looked good. What I can't believe Is that we finally got pics!!
[Re: Thumperdart]
#1415339
04/06/13 11:45 PM
04/06/13 11:45 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
Nice and clean. Well done
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
