Re: 904 transmission fluid
[Re: mshred]
#1413493
04/02/13 02:15 AM
04/02/13 02:15 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
I use whatever brand type F that A/Zone has on the shelf, plus 1 qt non detergent 30w oil.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: dartman366]
#1413498
04/02/13 03:13 PM
04/02/13 03:13 PM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
I use Hyundai SPIII because it's free and it's synthetic. I don't use a cooler.
[Re: Guitar Jones]
#1413499
04/02/13 05:38 PM
04/02/13 05:38 PM
Posts: 3,421 Toronto
mshred
Toronto
Thanks for all the suggestions guys! I am going to be using a cooler, which I forgot to mention. It seems there are quite a few using Type F...I was going to use dextron or mercon, or even standard ATF, but how come ATF? Is it superior to the other stuff? Just trying to understand to....and now I have to figure out how much I need with my summit deep aluminum transmission pan Thanks!
[Re: Triple Threat]
#1413501
04/02/13 06:33 PM
04/02/13 06:33 PM
mshred
Toronto
This is my brothers post, worth the read on this subject.
https://board.moparts.org/ubbthreads/showflat.php?Number=7273186&page=0
Thanks for that link! It does help to understand the differences between the type F and the dextron/mercon stuff, but it sure as hell doesn't make the choice any easier.
I would imagine firmer shifts are more desirable? But then again, I am using stock type clutches and a transbrake, so maybe I want something like dextron or ATF 4 instead?
This might come down to the flip of a coin at the parts store lol
[Re: mshred]
#1413502
04/02/13 07:06 PM
04/02/13 07:06 PM
Posts: 20,862 A collage of whims
topside
A collage of whims
Way back at the dawn of time - OK, the early '70s - I worked for the "slippin' twins" (Bob & Don @ B&M), and they'd chuckle about their Trik-Shift fluid, which was actually just Type F repackaged with their label. I've used both Dex and F in the same trans before and couldn't really tell the difference; 10-sec SB/904 Duster footbrake car, basically stock trans with 4400 & later 5800 stall. Upgraded to a CRT 904 with the new/stronger motor, and John said to use Dex, so that's what's in it. I'm currently running F in my '64 Savoy street/strip car, which is a kinda-mild RB/727 3000-stall footbrake car that might run a 12.0, because the 2 trans guys involved on that one like F.
[Re: topside]
#1413503
04/02/13 08:12 PM
04/02/13 08:12 PM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
chrysler/mopar AFT-4 is what I use in my 904. red clutches, 4.2 lever 3000 stall. etc. etc. i've also used redline with no difference. atf-4 gets my vote.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: CHAPPER]
#1413507
04/04/13 09:55 PM
04/04/13 09:55 PM
Posts: 4,990 new jersey usa
11secdart
new jersey usa
I just changed the oil in my 904 . I`ve always used Type " F "and just bought it at Advance Auto Parts.
[Re: 11secdart]
#1413508
04/05/13 10:12 AM
04/05/13 10:12 AM
Posts: 9,881 Weddington, N.C.
Streetwize
Weddington, N.C.
All type F except 1qt of Dextron. An old mentor told me this 30 yrs ago that there is an ingredient found in Dextron that is not present in Type F that is required (specified by GM and MoPar) and intended to keep the MoPar seals pliable and properly 'swelled'. So as long as you have some Dextron in the case all stays good and no leaks...FWIW Could be an 'old urban myth' but I remember some places used to sell a 'universal' trans fluid so maybe there are ingredients not in both
[Re: Streetwize]
#1413509
04/05/13 10:47 AM
04/05/13 10:47 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
2 quarts of synthetic and the rest is whatever brand of Type F...as recommended by my transmission and converter builder.
