Page 2 of 3 1 2 3
Re: 34 Dodge Update [Re: B1arno] #1413387
07/05/13 02:12 AM
07/05/13 02:12 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
It had a fabric covered top originally over a wood framework. I'm not sure why they were done this way. My guess is cost savings in production. Maybe someone else can enlighten us?
Arno
I don't think they had the capacity to stamp a full metal roof until 1935. Mopar was about the first to have a full metal roof in 35, everything before that had a cloth insert unless it was just tin tacked with nails over a wood frame. Gene
Re: 34 Dodge Update [Re: B1arno] #1413388
07/05/13 06:39 AM
07/05/13 06:39 AM
moparx Offline
moparx  Offline
Arno
the reason this was done this way was because there wasn't a press or die big enough to stamp a top section in one piece. all manufacturers did this untill 36 or 37. in the early days it was only possible to stamp front, rear, and rt/lft sides then weld together to form the top. the welds were often very poor as the joints weren't precise by any means. they were then leaded over to fill the seams. the resulting hole was then filled with a wooden framework covered with "chicken" wire and a fabric covering.[my humpback has the luxury of having 2 holes in the roof made this way.] i read this somewhere a million years ago in a book about henry ford.......
gene, you are right. mopar was the first to make a solid top, but in 35 the sedans still had a roof insert, at least the early production ones had them. not sure about 36, but all had a "one piece" top in 37.
Re: 34 Dodge Update [Re: moparx] #1413389
07/06/13 12:24 AM
07/06/13 12:24 AM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
Arno
I knew there would be people on here that could answer that. Thanks guys!
Re: 34 Dodge Update [Re: MuuMuu101] #1413390
07/07/13 03:37 PM
07/07/13 03:37 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
That's going to be a sweet ride!
Moparlee
Re: 34 Dodge Update [Re: Robbins] #1413391
04/12/14 09:20 PM
04/12/14 09:20 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
Been about 6 months since I have been able to work on the 34. Hopefully have now remodeled my last bathroon and got back to the car on Friday. It took awhile to get things sorted in my head again as to what to tackle next. As usual I started on several areas at once. It seems to help when I get stuck for ideas to stop on one area and move to another. Not really my style but it seems to work on this thing. I've never done sheet metal replacement before so this is all new to me. I was able to buy some patch panels but many patches need to be custom bent. Fortunately I have a friend that was a body man and he gives me some pointers if I get stuck. I feel for you guys in the rust belt. Here are a few new pics.
Re: 34 Dodge Update [Re: B1arno] #1413392
04/12/14 09:25 PM
04/12/14 09:25 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
That first picture is the passenger side where the A pillar meets the roof. The sheet metal was pretty much gone. Had to figure out how to patch this rather complicated piece. Ended up making it in two pieces that will be welded together. This pic is where I left off today, still needing some tweeking, but getting there.
Re: 34 Dodge Update [Re: B1arno] #1413393
04/12/14 09:28 PM
04/12/14 09:28 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
The replacement rear panel welded in place. I have to recreate the ends where it transitions into the rear quarters.
Re: 34 Dodge Update [Re: B1arno] #1413394
04/12/14 09:30 PM
04/12/14 09:30 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
Lastly, this is the passenger side front cowl patch panel. It also has some more fitting to be done but pretty close.
Re: 34 Dodge Update [Re: B1arno] #1413395
04/13/14 12:51 AM
04/13/14 12:51 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Hey Arno,
Where did you get the rear splash pan ? The last time I worked on mine, nobody was making Mopar stuff. We had to adapt Ford pieces or make them from scratch.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: 34 Dodge Update [Re: 5wndwcpe] #1413396
04/13/14 01:01 AM
04/13/14 01:01 AM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
Hey Arno,
I got all my patch panels from Floyds Body Shop.
http://rileyreproductions.com/patchpanels.html
Their stuff is very nice/accurate and reasonably priced as far as I'm concerned. I'm looking at Ford repro drip mouldings for mine.
Re: 34 Dodge Update [Re: B1arno] #1413397
04/13/14 08:41 AM
04/13/14 08:41 AM
moparx Offline
moparx  Offline
you are doing good arno ! keep up the good work !
Re: 34 Dodge Update [Re: moparx] #1413398
04/15/14 12:25 AM
04/15/14 12:25 AM
Mt. Eden Ky.
Hemi Allstate Online content
Hemi Allstate  Online Content
Mt. Eden Ky.
It's GREAT to see this progress.
Keep up the good work Arno!
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: 34 Dodge Update [Re: Hemi Allstate] #1413399
04/15/14 05:50 AM
04/15/14 05:50 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
i think we all have had our projects pushed back at one time or another,,,,glad your back on it
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: 34 Dodge Update [Re: fstfish66] #1413400
04/19/14 08:31 PM
04/19/14 08:31 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
Got a little time to work on it again today. The bottoms of the doors had some pretty funky rust repair done on them so I'm cutting out the old repair to see what I can do. The first three pics are of the pass side and the last two are the drivers side. Now to figure what I'm going to do to fix it!
Re: 34 Dodge Update [Re: B1arno] #1413401
04/19/14 08:31 PM
04/19/14 08:31 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
#2
Re: 34 Dodge Update [Re: B1arno] #1413402
04/19/14 08:32 PM
04/19/14 08:32 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
#3
Re: 34 Dodge Update [Re: B1arno] #1413403
04/19/14 08:33 PM
04/19/14 08:33 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
#4
Re: 34 Dodge Update [Re: B1arno] #1413404
04/19/14 08:33 PM
04/19/14 08:33 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
Last
Re: 34 Dodge Update [Re: B1arno] #1413405
04/19/14 10:39 PM
04/19/14 10:39 PM
dogdays Offline
dogdays  Offline
34 ford patch panels?
R.
Re: 34 Dodge Update [Re: dogdays] #1413406
04/20/14 04:47 AM
04/20/14 04:47 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
R.
there is a guy called the plymouth doctor, he makes panels but i dont know for what all he makes panels for or how to get a hold of him,,,
2015 cherokee
2013 R/T classic
Page 2 of 3 1 2 3
