Re: launch RPM's [Re: tboomer] #1413022
04/03/13 08:04 AM
04/03/13 08:04 AM
ill
dennismopar73 Offline
ill
Been in heavy cars for some time , The higher RPM seam to slow the heavy car down , Lower RPM seam to make the car faster IDONO??
Now My car is light ,I say light at under 3000#, The 60 does not care if it is 3500 rpm or 2000, only couple # different ,so I leave at 2500,
I think a lot has to do with the combo , air in tires, converter, cam, and gearing,
Trans brake could make some difference, more so in RT than et? ,
Re: launch RPM's [Re: dennismopar73] #1413023
04/03/13 09:53 AM
04/03/13 09:53 AM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Must be missing something here, I thought reaction time had to do when the driver let the car move? Cant see what RPM has to do with any of it? Can someone explain please? 60ft time I can see, but not the RT...
Re: launch RPM's [Re: Dodgeguy101] #1413024
04/03/13 10:02 AM
04/03/13 10:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Its when the light turned green to when the front tires
broke the beams(forward beam)... think of this extreme.
if you idle off the line to 5000 rpm off the line..
which will move past the beam first
Re: launch RPM's [Re: dennismopar73] #1413025
04/03/13 10:06 AM
04/03/13 10:06 AM
Az
Crizila Offline
Crizila  Offline
Az
I guess there are a lot of factors involved here ( not to mention the human factor ). Next time I go out, I will go back to my "normal" launch procedures ( tires at 12 psi and launch at 2700rpm ) and see if my RT's return to - acceptable .
Fastest 300
Re: launch RPM's [Re: MR_P_BODY] #1413026
04/03/13 10:20 AM
04/03/13 10:20 AM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Ok, makes sense, thanks
Re: launch RPM's [Re: Dodgeguy101] #1413027
04/03/13 10:35 AM
04/03/13 10:35 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The closer you can get to the max torque of the engine
the quicker it will move the mass
