Page 2 of 4 1 2 3 4
Re: Water/Meth Injection [Re: Cab_Burge] #1411509
03/31/13 05:15 PM
03/31/13 05:15 PM
MN
hemidup Offline
hemidup  Offline
MN
I would not inject water into a motor mixed with anything I would and will inject straight alcohol H2O expands to two hundred times it size when heated and converted to steam Not much room for anything else in the combustion chambers is there Steam doesn't burn worth a hoot either
Make's perfect sense Cab. I made 20 more hp without W/M @ 160* air intake temps than I did with W/M @ 115 air intake temps with the same fuel and timing tables.
I'm changing out my windshield washer mix and going with straight denatured alcohol that I can buy from the hardware store.
Jerry Williams.
Re: Water/Meth Injection [Re: hemidup] #1411510
03/31/13 07:32 PM
03/31/13 07:32 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
why not spray water? http://www.youtube.com/watch?v=JYw2q7igDGs helps control the burn. Makes 93 act like 116. you can run as much advance as you need... this is also worth looking at..
Re: Water/Meth Injection [Re: Mr.Yuck] #1411511
03/31/13 08:36 PM
03/31/13 08:36 PM
Repeat that test with straight alcohol, Methanol, Ethanol, Denatured or what ever is easist to get for you, and see what the results are You won't be disappointed BTW, the inlet temps on most boosted motors dictates how much total timing they can run Alochol absorbs heat as it evaporates
Re: Water/Meth Injection [Re: Cab_Burge] #1411512
03/31/13 09:56 PM
03/31/13 09:56 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
On any engine charge cooling has its benefits, moreso on boosted engines, which is where using alcohol comes into play nicely
This business of using water to slow combustion, however, just sounds like a bandaid.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Water/Meth Injection [Re: OUTLAWD] #1411513
03/31/13 10:02 PM
03/31/13 10:02 PM
All the makers seem to recommend water and meth not just meth.
Re: Water/Meth Injection [Re: ] #1411514
03/31/13 11:29 PM
03/31/13 11:29 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
using an inj kit will require some planning,testing like they say your results may very.
Re: Water/Meth Injection [Re: ] #1411515
03/31/13 11:38 PM
03/31/13 11:38 PM
Straight Metanol alcholol absorbs,sucks, moisture out of the air and that mixture ends up making it very corrosive, especially on aluminum, don't ask me how I know that Maybe the kit makers want you to dilute the Methanol enough to stop the corrosion from adding a small amount of moisture to it like it will do on its own If so I would use either straight Ethanol or denatured alcholol like you can buy in any Wal Mart or paint or hardware store
Re: Water/Meth Injection [Re: Cab_Burge] #1411516
04/01/13 09:07 AM
04/01/13 09:07 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I think the instructions call for the washer fluid to be at 49% alcohol.
Re: Water/Meth Injection [Re: Mr.Yuck] #1411517
04/01/13 03:50 PM
04/01/13 03:50 PM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Well as far as I understand,there are a couple reasons for water/meth instead of straight alcohol.
As stated corrosion: eats everything - can`t let it sit either.
:fire hazard -water/ meth is not fuel ,straight meth is and requires all the safety and restrictions gas does. IE.lines,tank,shipping,storage etc...
I`ve seen test after test,the stuff works. Does meth only work better,yes.... But what is your goal??? What are you willing to do to get it????
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Water/Meth Injection [Re: Mr.Yuck] #1411518
04/01/13 04:42 PM
04/01/13 04:42 PM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
They supposedly recommend using a 50/50 mix of water/methanol for the best combination of air charge cooling and detonation control.
Most washer fluids rated between -20 and -35 degree's below zero contain between 30-40% methanol (but not all so check the lable)which is what I have used. Pretty hard to find in summer here though
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: Water/Meth Injection [Re: Mr.Yuck] #1411519
04/01/13 04:49 PM
04/01/13 04:49 PM
megajoltman Offline
megajoltman  Offline
Most washer fluids rated between -20 and -35 degree's below zero contain between 30-40% methanol which is what I have used. Pretty hard to find in summer here though
Procharged 350Z
Re: Water/Meth Injection [Re: 6bblFLASH] #1411520
04/01/13 05:43 PM
04/01/13 05:43 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
Thank you for the pictures. What is the diameter of your blower crank pulley? 6 or 7 inches?
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Water/Meth Injection [Re: mopardude318] #1411521
04/01/13 11:51 PM
04/01/13 11:51 PM
N.E. Ohio
N.E. Ohio
7". My drive ratio is 2.13 to 1.
Re: Water/Meth Injection [Re: 6bblFLASH] #1411522
04/02/13 04:27 AM
04/02/13 04:27 AM
N.E. Ohio
N.E. Ohio
Well I think I have found a solution.
I drilled a passage from the side of the carb. main body between the venturi`s which intersects with a hole coming up from the bottom thru the baseplate inline with the air cleaner stud.
This base already has a 5/8 recessed hole in the center of the throttle blades. I will drill it thru and tap 1/8NPT and thread a nozzle there spraying straight down into the top of the blower.
The outside passage will also be tapped to plump the high pressure water/meth.
The rest will be like any other install.
I will take some pic`s once its done.
Re: Water/Meth Injection [Re: 6bblFLASH] #1411523
04/02/13 02:26 PM
04/02/13 02:26 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Sounds really slick!
Re: Water/Meth Injection [Re: 6bblFLASH] #1411524
04/02/13 02:46 PM
04/02/13 02:46 PM
Gilroy,CA.
Gilroy,CA.
Sweet idea. Please remember to post those pics when youre done!
What carb are you currently using?
For my B&M blower, I'm thinking of using one of the holley 750 supercharger carbs.
Re: Water/Meth Injection [Re: mopardude318] #1411525
04/02/13 03:26 PM
04/02/13 03:26 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
WI works great on a tow rig .... and cleans-up the WHOLE top-end of the motor very nicely PLUS it allows you to run lower octane fuel with more timing ..... NO power increase though ....
Re: Water/Meth Injection [Re: dOc !] #1411526
04/02/13 04:38 PM
04/02/13 04:38 PM
IL
furious70 Offline
furious70  Offline
IL
Edelbrock varijection had a nice on top of carb setup. out of production for many years though.
Hugh had a few very interesting things to say about bsfc and water
http://books.google.com/books/about/Turbochargers.html?id=pewyJ3_F4XMC
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Water/Meth Injection [Re: furious70] #1411527
04/02/13 04:44 PM
04/02/13 04:44 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
I had a Spearco unit on my gasser Dodge dually with a weak-400 motor .... it would clean-up a dirty plug DIRECTLY ...almost like it was sandblasted..... but it would go through a TON of water !!
Re: Water/Meth Injection [Re: dOc !] #1411528
04/02/13 06:56 PM
04/02/13 06:56 PM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
I still have a new one in a box somewhere. They always reminded me of a windshield washer bottle/pump with a simple plastic nozzle for an injecter...
The snow performance units are more substantial looking. But, that is why they cost more. They are much more scienced out than an old Spearco.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Page 2 of 4 1 2 3 4
