Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: hp383] #1410376
03/29/13 09:58 AM
03/29/13 09:58 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I'm not sure about the toilet cleaner, wouldn't that possibly be too corrosive?
You don't leave them in there for a long time , or over night. soak for a few minutes , scrub with a plastic brush and rinse in water. For the stuff you get to use at home might take a little more effort?
But the white vinegar mentioned after I posted sounds like a good alternative , it's not sure acidic , I'll have to give it a try .
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: Anselmi] #1410377
03/29/13 10:00 AM
03/29/13 10:00 AM
JohnRR Offline
JohnRR  Offline
Has anyone used RPM (Rust Prevention Magic) to protect the connectors after cleaning them?
Use electric dielectric grease , if the factory used that on them way back then you wouldn't see half the oxidation issues , some car makers use it now .
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: JohnRR] #1410378
03/30/13 12:39 AM
03/30/13 12:39 AM
Upstate, NY
sixpack4spd Offline
sixpack4spd  Offline
Upstate, NY
I thought someone just dipped them in muriatic acid to instantly clean them up??? Never tried it myself, but maybe look into it?
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: sixpack4spd] #1410379
03/30/13 01:15 AM
03/30/13 01:15 AM
That's swimming pool acid right? maybe taking the terminals/pigtails out of the bulkhead & let them dangle in a small lid of it & see how it does
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: RapidRobert] #1410380
03/30/13 01:20 AM
03/30/13 01:20 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
Today I used some of the "DeOxit" on the female terminals and blew it out with compressed air. The male spades were cleaned as well. I used a file to scrape even though there was no corrosion, only some tarnished copper.
I expected there to be more gunk since the car is 43 years old. I did have the harness out in 2002 when I painted the car and engine bay. maybe I cleaned them then? Heck... that was 11 years ago!
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: Kern Dog] #1410381
03/30/13 01:24 AM
03/30/13 01:24 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
No di-electric???
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: RSNOMO] #1410382
03/30/13 01:39 AM
03/30/13 01:39 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
How much of that dielectric are you supposed to use? Just a dab to coat the contacts?
I haven't put the connectors back together yet.
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: Kern Dog] #1410383
03/30/13 07:22 AM
03/30/13 07:22 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Some info on the dielectric grease:
http://www.wisegeek.org/what-is-dielectric-grease.htm
You can apply generously to the "pockets" in the connectors, the grease is not conductive, and is designed to prevent oxygen, and moister, from corroding or tarnishing the contacts.
However I think the author of the page may not be a "car" guy:
Dielectric grease is widely used as a sealant for spark plugs in gasoline or diesel engines, as well as on the gaskets of multi-pin connectors in the electrical systems of vehicles and boats.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: hp383] #1410384
03/30/13 10:24 AM
03/30/13 10:24 AM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
I used this when I reassembled after cleaning. Worked awesome and a little less mess than the dielectric grease. Time will tell if it is as good
http://www.heartland-marketing.com/whip.html
