How common is a .055" OS 440 cylinder really too thin?
#1409816
03/27/13 03:02 PM
03/27/13 03:02 PM
BradH
I'm curious based on people's experiences w/ sonic-checking OEM 440 blocks how common it would be that taking one to .055" or .060" oversize would really be taking a chance w/ thin cylinder walls. Both my current .060" OS rebuild and my backup-in-progress .055" OS were bored to those dimensions "due to circumstances out of my control" and neither were sonic-checked before that was done to verify wall thicknesses. As someone I used to hang out with a lot used to say, "It is... what it is...". ![](/ubbthreads/images/graemlins/shruggy.gif) These are early '70s blocks (as is my last untouched core 440 block), which IIRC doesn't mean squat as far as whether the walls are actually thicker or not than any other generation of OEM 440 block. So it makes me wonder if I'm really playing Russian Roulette(sp?) with them making 600+ HP. Thanks.
Re: How common is a .055" OS 440 cylinder really too thin?
[Re: Thumperdart]
#1409819
03/27/13 04:41 PM
03/27/13 04:41 PM
BradH
Spend the coin and sonic check it.............no other way of knowing.
Unfortunately, no shop that I know of in the general area has a tester and my budget doesn't currently include dropping $1K for a good one just for myself.
From what I can tell, the cheap testers I've researched need to have the bore probe "massaged" to even get a reasonable reading which has discouraged me from bothering to try one of those out, either.
[Re: 80fbody]
#1409822
03/27/13 04:52 PM
03/27/13 04:52 PM
BradH
I'm rolling the dice as well on a .060 440 block I have that's pretty fresh...
Still looking for rings? ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: Thumperdart]
#1409823
03/27/13 04:55 PM
03/27/13 04:55 PM
BradH
Where the hell do you live...
You'd be surprised... but the local machine shops haven't seemed to think they need to invest in a sonic checker. ![](/ubbthreads/images/graemlins/shruggy.gif)
I'd probably have to drive a couple hours away to find someone with one, which starts to increase the PITA factor significantly. ![](/ubbthreads/images/graemlins/maad.gif)
[Re: BradH]
#1409825
03/27/13 05:14 PM
03/27/13 05:14 PM
Posts: 13,415 Marion, South Carolina [><]
an8sec70cuda
It's the same way around here, but I got lucky and found a shop (Naylor's Racing Engines) a little over an hour away that could do it. They had to find their sonic checker first, lol. He said they never use it anymore since all the blocks they build (mostly BB chevy Dart blocks, etc.) are aftermarket and never have any issues. Charged me $40 to check it. I called several shops and noone had one or could even tell me who to go to...even called PAR and Gene Fulton's.
[Re: 64Post]
#1409830
03/27/13 06:43 PM
03/27/13 06:43 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
I sidestepped a debate with a guru on FBBO that says there are no problems “blind” (not sonic checking) boring a stock block to +.060,” and that any problems with a thin/weak cylinder would have shown up at +.030.”
Who ever said that is a dumb a$$
[Re: VernMotor]
#1409831
03/27/13 06:53 PM
03/27/13 06:53 PM
Posts: 3,103 Phila Pa
scatpacktom
Phila Pa
I bought my own sonic tester and now that I have it I test everything. That said "ignorance is bliss" now I stress out over everything. Recently had a Hemi block that was killer on the major thrusts on one bank and just so so on the other bank. Then it had this one area way down low that measured .119 that is when you lay in bed at night and think.
Honestly, Brad talking about it here will get you nowhere, or worse than that Pee'd off and nowhere.
Get them tested and and make a choice OR Turn the key and forget about it.
[Re: AndyF]
#1409835
03/27/13 07:05 PM
03/27/13 07:05 PM
Posts: 462 Stockholm, Sweden
fed
Stockholm, Sweden
Sleeve it! My 340 have 8 sleevs!
Cuda, -70 Valiant-65 AWB, Valiant Signet200 -65 Topchopped dragcar. Topolino Fuel Altered. NostalgiaFED Sold, SuperComp Bantam Altered, Sold Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
