Re: Silverfish Update...Getting Close !!
[Re: mshred]
#1408880
03/26/13 10:37 AM
03/26/13 10:37 AM
Posts: 803 Idabel,Oklahoma
Gary Robbins
Idabel,Oklahoma
Damn, looks good!
Where did you get those carbon fiber strips on the cage from?
Jerry Bickel!!!
[Re: tubtar]
#1408882
03/26/13 04:09 PM
03/26/13 04:09 PM
Gary Robbins
Idabel,Oklahoma
I gotta ask about the fuel system ........ the Magnafuel pumps don't mind drawing ? Not being critical , just curious. Great looking build for sure.
Never ran a amp draw test on pump if that's your ?
[Re: BloFish]
#1408886
03/26/13 07:37 PM
03/26/13 07:37 PM
Gary Robbins
Idabel,Oklahoma
Are those QA1's on the front, if so what size and rate spring are you using?
Just curious...
Yes they are double adjustable QA1'S and work great for me...Got them from Reilly Motorsports when i got my alterkation frontend!!
Will check spring rate when i'm out in the shop this evening and will pm ya!!
[Re: jbmopars]
#1408887
03/26/13 07:44 PM
03/26/13 07:44 PM
Gary Robbins
Idabel,Oklahoma
Looks great Gary, but you went and changed the wing on me before I could get my version finished.
You are right...Didn't have it dipped when i sent pics and forgot to send new one's
Doesn't matter as it looks awesom.
[Re: Gary Robbins]
#1408889
03/26/13 11:06 PM
03/26/13 11:06 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Nope......electric fuel pumps like to push , as opposed to drawing fuel. They will , but I think they work harder to do their job. Usually , I see them mounted behind and below the tank or cell. I am guessing there is a pick up that angles to the rear to the cell on yours ? Or am I seeing the return plumbed into the top of the cell ? I looked twice , and I am still not exactly sure what I saw.
[Re: Gary Robbins]
#1408893
03/27/13 07:33 AM
03/27/13 07:33 AM
Posts: 9,883 MI, usa
dvw
MI, usa
I checked my Perfomance Engineering pump which I believe is very similar, 7.5 amps. Doug
[Re: dvw]
#1408894
03/27/13 09:23 AM
03/27/13 09:23 AM
tubtar
St. Paul , Mn.
DVW , your pic makes it a lot clearer. I didn't see the pick up on Sliverfish's shot , but the line I was wondering about is clearly the return. If that's the last time I get confused , then I should have my buggy sorted out by Saturday. On the Fish , I saw filter and I saw pump....that registered. The overflow is obvious. I don't know if it was the massive diameter of the return or lack of coffee , but it threw me.
[Re: BloFish]
#1408895
03/27/13 10:21 AM
03/27/13 10:21 AM
Gary Robbins
Idabel,Oklahoma
Just curious...
Will check spring rate when i'm out in the shop this evening and will pm ya!! [/quot
Thanks...
Had to work late...Usually go home early on Wednesday'S and should be able to check then !!!
My car is 3150# with me in it,sent all weights to santhuff and they sent 325# front & 125# back springs!!!
