carter avs adgustments
#1406973
03/23/13 10:11 AM
03/23/13 10:11 AM
Posts: 1,960 Kenosha, Wi
GOLDMYN
Kenosha, Wi
Hi, can someone tell me what the screw in the upper center does, I've turned it to various setting with no results?...thanks
Semper Fi
Re: carter avs adgustments
[Re: GOLDMYN]
#1406974
03/23/13 10:58 AM
03/23/13 10:58 AM
RapidRobert
I'm thinking that it is a "hot idle compensator" used on some OE carters that lets additional air in under some conditions. That's as much as I know. I was not aware that it was adjustable
[Re: ScottSmith_Harms]
#1406980
03/23/13 01:14 PM
03/23/13 01:14 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Yes that the ones I have seen alot of. Dont see many like the OP carb with the one mixture screw. Thats some real purdy carbs. Ron
[Re: GOLDMYN]
#1406981
03/23/13 04:05 PM
03/23/13 04:05 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
The carb is a 4617s for 1969 383 w/4spd
That carb is for 440HP with auto trans , the correct carb for 383 w/4spd is 4615S
[Re: JohnRR]
#1406982
03/23/13 05:21 PM
03/23/13 05:21 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
John,I really hate to correct you but the 4617 is a 69 4spd carb,me even got's one !!
Re: carter avs adjustments
[Re: TJP]
#1406985
03/23/13 09:30 PM
03/23/13 09:30 PM
62maxwgn
Blair County,PA
OK my :two cents: for what it's worth.
the late 60's brought on emission controls from bit brother. The thought behind the single adjustment screw was that it would limit "peoples" ability to fatten up the mixture by capping off the Normal mixture screw IE: being two. Those screws were "FIXED" and the single screw limited adjustments that would KEEP the Emission in range of BIG BROTHERS targets. HMM a GOOD, but BAD idea as the car so equipped ran to lean and resulted in MEGA drivability issues / complaints. The SAVVY dealership / mechanic realized that by pulling the two LOWER plugs they could then access the HIDDEN mixture screws, tweak it up and the ISSUES went away. The design was only around for a year or two for obvious reasons. Feel free to flame away if what i have posted is incorrect. An old man from back in the day
That's why the mixture screws have been replaced on the one I have!
[Re: 62maxwgn]
#1406986
03/23/13 10:08 PM
03/23/13 10:08 PM
Posts: 7,545 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Good info here and I'll just add one very basic comment based on the 'rookie' mistake I made with my AVS:
That needle screw or screws is an air circuit, not fuel. So backing it out adds air to the mixture, not fuel. Live & learn.
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: 67SATisfaction]
#1406987
03/24/13 01:14 AM
03/24/13 01:14 AM
383man
Balt. Md
There are also some Holley four barrels like that. I think most Holleys like that say it on the side as they control the idle air bleed air. Turning the screw out leans it out. Ron
