Draglink - which way does it go back in? 70 cuda #1406934
03/23/13 08:54 AM
03/23/13 08:54 AM
K
kielbasa Offline OP
kielbasa  Offline OP
K
Hi guys, in process of reassembling and looking at my photos during disassembly, my labeling and pics don't match up. The draglink can be installed two ways (wrong way and right way), and I think I have it correct, but want to make sure.
One end of the draglink has more of a kink to it, and I assume that goes on the pitman side? And the gentler bend on the idler side?
Just wondering if someone can verify....Thanks in advance!!
Re: Draglink - which way does it go back in? 70 cuda [Re: kielbasa] #1406935
03/23/13 10:54 AM
03/23/13 10:54 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Down and back.
Re: Draglink - which way does it go back in? 70 cuda [Re: kielbasa] #1406936
03/23/13 02:01 PM
03/23/13 02:01 PM
New Mexico, USA
attaboy Offline
attaboy  Offline
New Mexico, USA
If you put it in wrong It'll probably rub against the oil pan. Looking at it you'de think that it wouldn't be that much difference but with mine it rubbed against the oil pan until I rotated it 180.
attaboy
Re: Draglink - which way does it go back in? 70 cuda [Re: attaboy] #1406937
03/24/13 01:43 PM
03/24/13 01:43 PM
K
kielbasa Offline OP
kielbasa  Offline OP
K
hmmm, well my engine isn't installed yet - so won't be able to tell if it rubs oil pan yet.
just seems weird to me that the dust shields on the front rotors are labeled left and right (and you physically can't install those backwards), but yet spindles and draglink (which CAN be incorrectly installed) aren't labeled left or right.
Re: Draglink - which way does it go back in? 70 cuda [Re: kielbasa] #1406938
03/24/13 02:02 PM
03/24/13 02:02 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
...70 E body
